Losing Pressure?
Old Feb 7, 2002 | 07:59 PM
TurBoXBirD16's Avatar
Default Losing Pressure?
i don't know I am losing air when i boost..
i checked all the pipes, it's all fine
i am thinking of my BOV
it sounds like coming out frm the bov
but it doen't happen all the time
it usually happens when i am in second or third gear...
do i need to adjust the bov??
Old Feb 7, 2002 | 08:15 PM
5thgen's Avatar
Default Re: Losing Pressure? (xbird)
what car?
intercooler?
boost controller?
when does it lose boost?.....eg. 5000 rpm
how much boost does it lose?
You might want to get a boost controller and hook it up from an intake manifold source and then to the actuator of the turbo. You can make a boost controller, or buy one new for around $70 and up. Oh yeah, If you don't have a boost gauge (I assume you do) get one.
Old Feb 7, 2002 | 10:35 PM
Default Re: Losing Pressure? (5thgen)
its' a honda civic ex with greddy kit
no intercooler
no boost controller
just running 5.5 lbs boost
i think it runs at around 3 to 4 lbs boost whenever it starts boosting
it's only 70 bucks boost controller???? it thought it cots like around few hundreds bucks....
what brand?? is a manual boost controller make a difference than te electronics??
thanks
Old Feb 8, 2002 | 09:18 AM
TTT
Old Feb 10, 2002 | 10:20 AM
5thgen's Avatar
turbo xs has manual boost controllers (summitracing carries them). You can buy one of those or make one too ( http://www.c-speedracing.com ). It's basically a spring and a ball-bearing that holds pressure til' you hit a certain amount of boost, thus opening it up. They can be as good as electronic boost controllers in a sense that you can adjust your boost level and keep the boost level until redline. They are not, however, adjustable by a touch of a button inside the car. That and most EBCs have more features than just keeping a eye on boost.
I had the same situation you did with the greddy turbo/intercooler. Hooked up the boost controller sourced at the intake manifold, then to the turbo's wastegate actuator and my problem was gone. Good luck
ATS*Mark
Feb 18, 2004 01:25 PM
Tony Starks
Sep 23, 2003 06:53 PM
civicshowracing65
Feb 11, 2003 04:21 AM
greyzone
Oct 20, 2001 11:17 AM
Ray
Jul 7, 2001 07:34 PM
