vac of 20 ??
Old May 2, 2004 | 09:50 PM
Tex Blackwell's Avatar
Default vac of 20 ??
ok, i start the car, b16 in a ek hatch, t3 turbo, tial wastegate, greddy type s bov, front mount, dsm injectors
when the car idles, boost gauge reads 20 vac, i hit the gas, it hits 0 then back to 20 vac, no boost something hooked up wrong? on the tial wastegate i have the side hose hooked up to vacum and the top part unhooked since i dont have a boost controller, on the bov i hooked the big part to a vacum, something i'm doing wrong?
need help
thankx
Old May 2, 2004 | 09:53 PM
warwagon's Avatar
Default Re: vac of 20 ?? (mp3albums2k2)
have you driven the car yet or are you just revving it in your garage?
Old May 2, 2004 | 10:28 PM
MaxSterling's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mp3albums2k2 &raquo;</TD></TR><TR><TD CLASS="quote"> something i'm doing wrong?
yeah, drive it
Old May 2, 2004 | 10:31 PM
warwagon's Avatar
Default Re: vac of 20 ?? (MaxSterling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, drive it</TD></TR></TABLE>
i guarantee he hasnt pulled it out of his garage yet after he installed it!!!!!
NO LOAD MEANS PROLLY NO BOOST
Old May 2, 2004 | 10:34 PM
vteg's Avatar
New User
No load means no turbo love for you
Just drive it.
Old May 3, 2004 | 03:58 PM
Default Re: vac of 20 ?? (vteg)
sexy! boost now, but new issue, after i get out of first and shift into 2nd, the car makes no power, i get a code 3 (map sensor) i'm using the missing link, i pull the power, reset the ecu and runs find again, i try to make another pull, same thing happens again.
what i believe is happening is that air somehow gets past the missing link and hits the map sensor, i even switched map sensors thinking mine was gone, this code 3 makes the car not hit vtec as well. is there anyway that my missing link could be messed up? i tried blowing through it, and sucking, it seems like its working fine,
Old May 3, 2004 | 04:00 PM
sporkcrx's Avatar
what're you using for management?
Old May 3, 2004 | 04:04 PM
warwagon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mp3albums2k2 &raquo;</TD></TR><TR><TD CLASS="quote">sexy! boost now, but new issue, after i get out of first and shift into 2nd, the car makes no power, i get a code 3 (map sensor) i'm using the missing link, i pull the power, reset the ecu and runs find again, i try to make another pull, same thing happens again.
what i believe is happening is that air somehow gets past the missing link and hits the map sensor, i even switched map sensors thinking mine was gone, this code 3 makes the car not hit vtec as well. is there anyway that my missing link could be messed up? i tried blowing through it, and sucking, it seems like its working fine,</TD></TR></TABLE>
might be upside down... i dont know though never messed with one? Just heard of people thinking they are bad when upside down?
Old May 3, 2004 | 06:40 PM
Default Re: vac of 20 ?? (warwagon)
i'm using the vortec fmu 12:1 the problem is int he map sensor cuz i get the code 3 which is what flashes, the missing link is put on correctly, i think i might just have a bad valve inside the missing link itself, any1 know where i could get a new valve?
Old May 4, 2004 | 05:28 AM
bump
Old May 4, 2004 | 09:24 AM
warwagon's Avatar
flip that bitch over and try it just for me
niceguysfinishlast
Mar 22, 2008 02:28 PM
EF EG EK LOVE
Mar 20, 2008 09:36 AM
jtracing919
Apr 23, 2006 04:52 PM
376R
Nov 13, 2005 05:49 PM
NuclearB18B
Sep 10, 2003 09:06 PM
