V-AFC or S-AFC
Old Jul 17, 2001 | 04:20 PM
revhrdls's Avatar
Default V-AFC or S-AFC
Recently I decided to get 310s but I heard that the car will run rich under these injectors. I was thinking of buying either unit to control it and make it more stoich. What unit should I buy?, is there a difference between them?
Old Jul 17, 2001 | 04:22 PM
Ben Huynh's Avatar
Default Re: V-AFC or S-AFC (revhrdls)
S-AFC = Fuel Controller
V-AFC = Fuel and VTEC Controller
Old Jul 17, 2001 | 04:25 PM
dbman96's Avatar
New User
I ran ran 310s with no electronic compensation and there were no problems; when the car is running closed-loop it automatically adjusts. You may want to drop your baseline/static fuel pressure a bit, but mine had NO problems being too rich. Too lean, on the other hand...
As for the Apex stuff, the diff between the two is that the V-AFC has VTEC control built in and gives you the ability to build a fuel adjustment map for low throttle/high throttle and low cam/high cam (four maps) instead of just low throttle/high throttle (two maps) on the S-AFC.
At least that's how I understand it.
Old Jul 17, 2001 | 09:12 PM
TurboInteg95's Avatar
I have 310's in my car right now with no piggy back controllers, it runs fine. I just lowered the rise rate in my FMU to 8:1.
IgniteTeg
Apr 25, 2002 11:25 PM
ion_four
Apr 11, 2002 06:46 AM
redteg1
Feb 6, 2002 09:15 PM
1320Motorsports
Nov 22, 2001 06:29 AM
nfn15037
Sep 25, 2001 12:52 PM
