vafc & safc...wats the difference?
Old Feb 6, 2002 | 08:33 PM
redteg1's Avatar
Default vafc & safc...wats the difference?
vafc to regulate vtec....safc for wat? fuel regulation im guessing? just to make sure
Old Feb 6, 2002 | 08:35 PM
boosted hybrid's Avatar
Default Re: vafc & safc...wats the difference? (redteg1)
The VAFC controls vtec and fuel, the SAFC just controls fuel. Think of the SAFC as the VAFC w/o the Vtec control function built in.
Old Feb 6, 2002 | 08:39 PM
Adi Radoncic's Avatar
On Fire!
VAFC = Vtec Air Fuel Controller
SAFC = Map Sensor Air Fuel Controller
The Vafc is a vtec controller that has both vtec and fuel adjustments..
The Safc is solly an air/fuel controller that lets you tune your air fuel ratio and that also has a bigger range in adjustment in fuel settings over the Vafc....
Adi
Old Feb 6, 2002 | 08:53 PM
Etylorcen's Avatar
Default Re: vafc & safc...wats the difference? (newgsr)
How much cheaper is the safc than the vafc?
Old Feb 6, 2002 | 09:01 PM
Smashback's Avatar
Default Re: vafc & safc...wats the difference? (Etylorcen)
Heh, it's more actually. usually about 20 bucks
Old Feb 6, 2002 | 09:03 PM
On Fire!
Default Re: vafc & safc...wats the difference? (mplex2000)
You can get them for $305 shipped on groupbuycenter.com
Adi
Old Feb 6, 2002 | 09:04 PM
01-0720's Avatar
so if the safc controlls more options wouldnt it be better to get say a fields vtec controller and get a safc whould that be better than just getting a vafc
Old Feb 6, 2002 | 09:15 PM
On Fire!
Default Re: vafc & safc...wats the difference? (spizone)
No, you didn't get my answer right the safc doesn't controll more options it just gives you 10% more correction in your fuel settings than the Vafc.
By the way the if you have a vtec car and you want to be able to adjust the vtec points and your fuel settings go with the vafc because it has better tuning capabilities than the Fields because It lets you the user define eight points between 1000 and 7000 rpm in 100-rpm increments and tune those in the low cam position as well as high cam positions...
Adi
Traser
Nov 17, 2006 11:30 AM
B18ls*RAYON
Dec 27, 2004 07:32 AM
devonic
Apr 24, 2003 06:18 AM
10seconds
Jul 8, 2002 01:34 PM
BoroDB8
Apr 25, 2002 05:20 AM
