v-afc hack, what injectors to use?
I'm putting together a turbo on my b16 and am wonderng what injectors to use with a v-afc hack @8psi? I've seen a lot of people use 440's, but I'm wondering if 370's or 310's might be better. If I have 240cc injectors stock than putting in 440's would almost double my fuel, could it still pass emissons leaned out all the way at idle?
Once you put a turbo on it then you will need more fuel. As for using 440/450s with the hack you need to be able to lower the safc settings enough to where the map voltage is less than 3.1 volts. If you use a smaller injector then you wouldn't need to trim as much which would then trip the cel. Read this thread
https://honda-tech.com/zerothread?id=137901
to understand exactly what it is you are doing when you use the hack.
actually you cant use the hack when running 15 psi unless you get a gm 3-bar. Get yourself some rc 440's there more expensive than dsm but you wont have to mess with resistor boxs and stuff.
aemciv
Feb 26, 2003 11:31 AM
