using JUN ecu with boost temporarily do i need to worry?
Old Nov 24, 2003 | 07:14 PM
Nextelbuddy's Avatar
Default using JUN ecu with boost temporarily do i need to worry?
well im getting my gsr p72 ecu chipped tommorrow for hondata s200/b but i wont be gettig tuned for anoter 2 weeks. so i am going to use my backup ecu. its a p28 with the JUN program onit. (was using with my old type r motor) i have heard that these programs advance the timing significantly and since im boosted i am kinda worried. what do i need to do or worry about?
Old Nov 24, 2003 | 07:28 PM
HXMan's Avatar
Default Re: using JUN ecu with boost temporarily do i need to worry? (nextelbuddy)
Hmmmm...I would definatly not boost with it.
as long as you take it easy it should be fine I think.
Old Nov 24, 2003 | 08:09 PM
Default Re: using JUN ecu with boost temporarily do i need to worry? (HXMan)
yea i dont plan on boosting with it but what im worried abot is the timing even under normal driving conditions. since im running te hack right now the timing gets advanced already unlesss your at WOT like 5th gear pulls u know add on top of that the advancing of the timing of the JUN program i am kinda worried that even under normal NON boosting conditions that i could see a detonation problem. well well see i hope 2 weeks of not boosting will be worth wating getting it tuned with hondata. plus i just bought that edlebrock intake manifold for the b18c1 im going to put it on next week right before tuning. i hope i see a big increase over the stock gsr intake manifold.
Old Nov 24, 2003 | 10:07 PM
PHiZ's Avatar
Get someone to do you up a custom boost chip, and run that until you get tuned.
-PHiZ
Old Nov 25, 2003 | 07:37 AM
Default Re: using JUN ecu with boost temporarily do i need to worry? (PHiZ)
any other opinions?
Old Nov 25, 2003 | 08:33 AM
yellowhonda88's Avatar
JUN has wicked ignition maps that are 100% bass ackwards for what you want for a turbo tune, if you absolutly have to, I guess you could retard the hell out of the dizzy. I would not drive the car if it were me.
Brett
Old Nov 25, 2003 | 08:49 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">yea i dont plan on boosting with it but what im worried abot is the timing even under normal driving conditions. since im running te hack right now the timing gets advanced already </TD></TR></TABLE>
Your timing never advances further than your part throttle full advance... simply do not boost, as you know you shouldn't, and your timing isn't going to be advanced any more than it should be. It will be a little advanced at near atmospheric pressure conditions in the intake manifold, but as long as you're not boosting it won't matter, will it?
2kdrift
Nov 22, 2009 11:46 PM
krysted9354
Dec 21, 2008 12:05 PM
b18bcrxhf
Dec 9, 2006 07:25 PM
VTC_CiViC
Feb 13, 2004 02:57 PM
LSpimpTEC
Aug 10, 2003 01:37 AM
