Upgraded MAP?
Old Apr 5, 2006 | 06:56 AM
mrrugsr's Avatar
Default Upgraded MAP?
I believe the stock MAP on the GSR can read 10psi max. If i run 10psi daily and get a spike in boost for some reason the computer wont see the air coming in and wont and fuel......which will blow the motor tight? WELL ant aftermarket MAP i can get that will let me ready something like 20psi'ish for future upgrades and psi increases? BTW how hard are they to install and WHERE IS IT. thanks guys
Old Apr 5, 2006 | 07:19 AM
IHaveTurbos's Avatar
They are not hard to install and your factory one is located right on top of the TB.
Old Apr 5, 2006 | 07:25 AM
mrrugsr's Avatar
little black thing with circle top?
Old Apr 5, 2006 | 07:43 AM
Yes.
Old Apr 5, 2006 | 11:01 AM
mrrugsr's Avatar
know where i can pick up a 3bar?
Old Apr 5, 2006 | 11:18 AM
I believe in the sponsors forums someone was selling them for a good price, try doing a search and it should come up.
Old Apr 5, 2006 | 12:51 PM
mrrugsr's Avatar
i think i found one....75shipped that sound right?
Old Apr 5, 2006 | 12:59 PM
vietjdmboi's Avatar
yea $75 sounds right. that must be from Flamenco-T
Old Apr 6, 2006 | 04:43 AM
mrrugsr's Avatar
yea i think so, are these just plug and play or no
Old Apr 6, 2006 | 05:42 AM
redzcstandardhatch's Avatar
something different
Default Re: (mrrugsr)
no, you need to completely retune your car when changing your map sensor. everything reads differently.
you could also upgrade to a motorola 2.5bar map, they have been getting a large following lately. i love mine, and it was only 20 bucks.
Old Apr 6, 2006 | 07:38 AM
mrrugsr's Avatar
ye i knew you had to retune...i didnt explain better. i mean does it have a plug on it that just plugs right in to the old wiring or must you soder wire together.
2.5 MOTO.......whats the psi rating
See Are X
Oct 13, 2005 04:10 PM
lenn
Nov 21, 2003 10:04 PM
rattletrap
May 24, 2003 04:27 PM
