400 whp ??
Old Apr 3, 2006 | 09:42 PM
dd69ma's Avatar
Default 400 whp ??
has anyone hit those numbers on 16 pounds of boost with t3/t04e 57trim .63 a/r ?? if so what ap did you use ?
Old Apr 3, 2006 | 10:25 PM
btotherizzle's Avatar
a fork definately not the spoon
Old Apr 3, 2006 | 10:52 PM
f1 vtec's Avatar
Default Re: 400 whp ?? (dd69ma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dd69ma &raquo;</TD></TR><TR><TD CLASS="quote">has anyone hit those numbers on 16 pounds of boost with t3/t04e 57trim .63 a/r ?? if so what ap did you use ? </TD></TR></TABLE>
Many other issues will determine what power you end up making(obviously).But i think 16 pounds on a 57trim would get you around 350hp.
Whereas with 16 pounds on a t67 you are looking at around 400+hp
Old Apr 4, 2006 | 12:47 AM
morgan@synapse motorsport's Avatar
yeah on a 60-1 ive seen 405whp at 16psi, so i think youll have to push at least 18psi to make 400whp
Old Apr 5, 2006 | 05:42 PM
dd69ma's Avatar
Default Re: 400 whp ?? (f1 vtec)
ok here are some other factors b18c1 skunk 2 intake edlebrock throtle bodie 550cc injectors aem fuel rail gsr cams cp pistons eagle rods stock block walbero fuel pump 255 tail wastegate 38mm 2.5 in exaust ic piping 3" down pipe inline pro cast irone mani and the turbo that I mentioned
Old Apr 5, 2006 | 05:49 PM
drintegra's Avatar
You will need more psi as that turbo is too small to flow the cfm you want to produce that power at the psi. Not too much higer just like 2-4 psi.
Old Apr 6, 2006 | 07:42 AM
Naterror's Avatar
Default Re: 400 whp ?? (drintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drintegra &raquo;</TD></TR><TR><TD CLASS="quote">You will need more psi as that turbo is too small to flow the cfm you want to produce that power at the psi. Not too much higer just like 2-4 psi.</TD></TR></TABLE>
That and bigger injectors. 550's will be maxed out before you hit 400whp, unless you give it some serious pressure. But even then I don't think it'll handle it.
B18c1integra
Jun 24, 2015 12:36 PM
1lowek2007
Dec 5, 2012 06:53 PM
paul93sir
Mar 17, 2004 06:04 AM
ID_ten_T
Jul 17, 2003 02:43 PM
B18C-RnVA
Dec 28, 2001 01:00 PM
