untuned GSR worth?
Old Aug 30, 2007 | 11:00 AM
agrn93ls's Avatar
Default untuned GSR worth?
i am selling my car and dont really know what to ask for it. all it needs is a tune i was thinking i could get hopefully around the 8K range.
please let me know what you guys think
http://www.hondamarketplace.co...84393
edit, has fmu is what i meant by untuned
Modified by agrn93ls at 4:48 PM 8/30/2007
Old Aug 30, 2007 | 01:31 PM
RCautoworks's Avatar
Default Re: untuned GSR worth? (agrn93ls)
How long have you been driving it around untuned for ?
Old Aug 30, 2007 | 01:43 PM
ragethemachine86's Avatar
Default Re: untuned GSR worth? (RCautoworks)
tune it then sell it. i would think it would be difficult to sell the car untuned, first because the buyer will think you've been driving it around untuned even if you didnt and secondly the buyer won't be able to take a ride in it before he buys it.
Old Aug 30, 2007 | 01:44 PM
agrn93ls's Avatar
since january but i also have a blazer, a camaro, and a motorcycle i drive. its 7psi FMU. i just stay out of it. the money for tuning went to paying for the bottom end to be done. the LS bottom end spun two bearings and went two years on the same fuel setup.
Old Aug 31, 2007 | 08:29 AM
agrn93ls's Avatar
ttt
Old Aug 31, 2007 | 10:14 AM
ndogg's Avatar
Default Re: untuned GSR worth? (ragethemachine86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragethemachine86 &raquo;</TD></TR><TR><TD CLASS="quote">tune it then sell it. i would think it would be difficult to sell the car untuned, first because the buyer will think you've been driving it around untuned even if you didnt and secondly the buyer won't be able to take a ride in it before he buys it. </TD></TR></TABLE>
no point bumping this thread, here is your answer.
Old Aug 31, 2007 | 11:27 AM
agrn93ls's Avatar
Default Re: untuned GSR worth? (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">
no point bumping this thread, here is your answer.</TD></TR></TABLE>
thanks for the bump haha
i didnt ask how hard it would be thanks. i dont care. its has a FMU. thats the way it is.
Modified by agrn93ls at 2:41 PM 8/31/2007
Old Aug 31, 2007 | 01:16 PM
Code's Avatar
Not now Chief, I'm in the F'n zone!
So long as a compression test yeilds consistent good numbers across all cylinders you shouldn't have to worry.
Old Aug 31, 2007 | 01:52 PM
HiProfile's Avatar
Default Re: untuned GSR worth? (Code)
My brother bought a 'untuned' 96 GSR that had a bunch of small things, it had a DRAG kit IIRC. It had mechanical gremlins, easy to fix if you knew turbo'd cars well. He got it cheap for 5k, sold it for 6k IIRC. It needed a lot of TLC...
I'd expect you'd get at least $6k, but this would assume it was sold in WI, not TX. $7k would not be unreasonable IMO. A few bills for tuning and a flashy dyno slip, and you should get $7-8k no problem.
Old Aug 31, 2007 | 02:10 PM
agrn93ls's Avatar
Default Re: untuned GSR worth? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">My brother bought a 'untuned' 96 GSR that had a bunch of small things, it had a DRAG kit IIRC. It had mechanical gremlins, easy to fix if you knew turbo'd cars well. He got it cheap for 5k, sold it for 6k IIRC. It needed a lot of TLC...
I'd expect you'd get at least $6k, but this would assume it was sold in WI, not TX. $7k would not be unreasonable IMO. A few bills for tuning and a flashy dyno slip, and you should get $7-8k no problem.</TD></TR></TABLE>
thanks man. well mine has NO GREMLINS it truly is a perfect used car. although using perfect and used in the same sentance has to be taken in the proper way. but i am a fully certified mechanic and a perfectionist when it comes to the way i repair/replace things. so everything is good just needs a good new home.
link to car is in first post.
gearhead313
Jun 28, 2006 08:17 AM
ROCAFELLA2049
Oct 12, 2005 08:15 PM
integraracer94
Nov 8, 2002 04:14 PM
SIK IN DA HED
Feb 4, 2002 02:37 PM
Ben Huynh
Sep 19, 2001 06:01 AM
