FMU dyno sheet?
Old Jun 18, 2006 | 08:40 AM
gearhead313's Avatar
25 Year Member
Default FMU dyno sheet?
Has anyone used an FMU on a turbo setup and dyno'd it? I know I know there inconsitant and can pop the motor, but I just wondered if anyone has had expericence. I'm looking to build a light street boost setup and have an FMU laying around.
Old Jun 18, 2006 | 10:44 AM
rainmanEK's Avatar
big strong guy
Default Re: FMU dyno sheet? (gearhead313)
Plenety of cars have used FMU's with good results at lower boost levels. My fathers miata has been running on a FMU for over 3 years now!
Eric
Old Jun 19, 2006 | 04:53 PM
25 Year Member
thats excellent man. is he running upgraded injectors or an adjustable fuel pressure regulator?
I know there are people out there, i was just hoping they dyno'd and had the sheet to post!!!
Old Jun 19, 2006 | 05:03 PM
spooledex's Avatar
Default Re: (gearhead313)
dont' have the sheet. But I put down 310@8600 on 8psi with an FMU. Stock LS bottom end with B16a Head and to4 turbo setup. ran very lean up top though. Like 13.7.
Old Jun 19, 2006 | 05:25 PM
TorganFM.'s Avatar
Default Re: (spooledex)
FMU + BTM works. Consider getting something like a BTM to retard timing.
Old Jun 19, 2006 | 06:45 PM
hotimportcrx's Avatar
Default Re: (DanW)
dammm 8600 on stock ls rods....did it break from revving?
Old Jun 20, 2006 | 05:43 AM
25 Year Member
wow ya, thats revin an LS for sure! I learned my lesson hard on that.
BTM is a good idea. I'd assume if its leaning out, the BTM can save your ***...
Old Jun 26, 2006 | 07:06 PM
25 Year Member
no dyno's huh?
Old Jun 26, 2006 | 09:27 PM
BoostR41's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gearhead313 &raquo;</TD></TR><TR><TD CLASS="quote">wow ya, thats revin an LS for sure! I learned my lesson hard on that.
BTM is a good idea. I'd assume if its leaning out, the BTM can save your ***...</TD></TR></TABLE>
Jay I am sure you know my car ran that FMU set up for a few years with my stock block and never had an issue. I ran a cartech FMU that you could set the ratio externally, 450cc injectors, and afc. just was real careful not to pull to much fuel to mess with the timing on the AFC.
It always ran pig rich but it was safe
Old Jun 27, 2006 | 05:38 AM
25 Year Member
Default Re: (BoostR41)
Ah, i never did know you ran an FMU setup. I'm guessing you never dyno'd it?
What you listed is basicly what I have and want to employ; FMU, dsm 450's, and an afc... since i have them collecting dust. ...I'll have to pm you later.
Old Jun 27, 2006 | 08:37 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gearhead313 &raquo;</TD></TR><TR><TD CLASS="quote">no dyno's huh?</TD></TR></TABLE>
FMU dyno sheet on my 6th gen accord from a few years ago:
hp/trq
afr/boost
FYI - this is a 12:1 FMU using the Airtex inline fuel pump.
Old Jun 27, 2006 | 09:46 AM
HybridKOOP's Avatar
Default Re: FMU dyno sheet? (notoriousB)
Pretty damn steady for an FMU.
Old Jun 27, 2006 | 10:18 AM
BoostR41's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gearhead313 &raquo;</TD></TR><TR><TD CLASS="quote">Ah, i never did know you ran an FMU setup. I'm guessing you never dyno'd it?
What you listed is basicly what I have and want to employ; FMU, dsm 450's, and an afc... since i have them collecting dust. ...I'll have to pm you later.</TD></TR></TABLE>
yeah I just had the wideband in the car and got it to run well part throttle tip in but was always pig rich up top. Inline pro ran the FMU set up I had for years
Old Jun 27, 2006 | 11:06 AM
notoriousB's Avatar
Default Re: FMU dyno sheet? (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">Pretty damn steady for an FMU.</TD></TR></TABLE>
I thank the inline fuel pump for that. The only problem I ever had with that setup was a missing link that didn't always like to work right.
Old Jun 27, 2006 | 02:13 PM
25 Year Member
wow, that isn't bad at all. did you adjust fuel pressure at all with the extra pump?
Old Jun 28, 2006 | 04:52 AM
notoriousB's Avatar
nope, stock FPR, stock rail.
Old Jun 28, 2006 | 08:17 AM
Flamenco-T's Avatar
This is my old old old dyno sheet.....
Stock GS-R with drag 3 kit, stock injectors, stock everything..
stan
psikotc
Dec 14, 2006 07:00 AM
kovert
Aug 17, 2004 09:58 AM
stinker504
Sep 15, 2003 05:38 AM
hybridb18
Apr 21, 2003 10:46 AM
RTW DC2R
Jun 5, 2002 07:41 AM
