UBERTEG users, HELP!
Old May 19, 2004 | 06:53 PM
JDubya's Avatar
Default UBERTEG users, HELP!
You may have seen my other thread, but my car gets the hiccups when it's pretty warm/hot out. I would be driving and it sounds and feels like the motor just stops for a split second then goes back to normal. it would do this at idle, part throttle, full throttle, in vacuum, boost, whenever. And every once and a while the CEL would come on and then the car would kind of gargle then I'd have to shut it off then start it back up. It would also back fire sometimes. Also, the A/C would not blow cold at all, it was hot.
Now when it's cooler out the car runs fine. Why would the heat do this? Yes it is running very rich and I plan to get a wideband soon so I can tune it, but until then what can I do?
The code it threw was 43, Fuel Supply System. What could cause that?
Here's my setup:
Stock LS internals
t3/t04e
F-Max Mani
Tial WG
2.5 -> 3" DP w/full 3" exhaust
Intercooler
Greddy Type S BOV
440 cc injectors
walbro 255 intank
basemap in a P06
If anyone w/an LS has a similar set up that is tuned, could you send me the .bin file so I could try it out?
Modified by ALL MOTOR LS at 11:29 AM 5/20/2004
Old May 20, 2004 | 06:58 AM
JDubya's Avatar
Default Re: UBERTEG users, HELP! (ALL MOTOR LS)
up
Old May 20, 2004 | 07:16 AM
Joseph Davis's Avatar
What are your wideband readings?
No IC? Have you monitored charge temps?
Old May 20, 2004 | 07:28 AM
JDubya's Avatar
Default Re: UBERTEG users, HELP! (J. Davis)
I dont have a wideband yet, I PLAN to get one soon. Yes i have an IC i just put the main things that could cause a problem. But i guess lack of an IC could cause some high temps. First post updated...
Old May 20, 2004 | 09:04 AM
RotiEatter's Avatar
Ditto
Code 43 can be caused by o2 sensor.
Old May 20, 2004 | 09:53 AM
TurboJesse
Guest
Posts: n/a
Default Re: UBERTEG users, HELP! (RotiEatter)
mine did something similar, it would run hard as hell for the first few minutes then after it warmed up to temp. it would bogg/hesitate/sputter, etc. I replaced the o2 sensor and it cleared right up
Old May 20, 2004 | 01:00 PM
JDubya's Avatar
Default Re: UBERTEG users, HELP! (Mpir3)
When it does that hiccup thing, I can hear a relay clicking on and off. I think it's the PGM-FI Main relay. Or at least thats where the clicking's coming from...
Old May 24, 2004 | 12:17 PM
JDubya's Avatar
I know someone has a similar set up...
and what exactly does it mean when it backfires?
Old May 27, 2004 | 05:41 PM
JDubya's Avatar
Old May 27, 2004 | 05:46 PM
5STAR3's Avatar
sounds like your running too rich which is what you already know.
you cant diagnose any problems,and there is no point, if its not tuned/you dont have a wb.
Old May 27, 2004 | 05:56 PM
ImAcracker's Avatar
Loved
Tune first. Then ask questions. An unproperly tuned car will drive like ****.
Old May 27, 2004 | 09:05 PM
JDubya's Avatar
Default Re: (ImAcracker)
thats what i'm sayin. Does anyone w/a similar set up have a program that's somewhat tuned. I'm sure it's better than what i'm running now...
Old May 28, 2004 | 08:55 AM
JDubya's Avatar
Default Re: (ALL MOTOR LS)
The thing i dont get is, why is my PGM-FI Main Relay clicking off? When it clicks off for a split second, that's when it hiccups. Could the relay be going bad? or is there something else causing it?
Old May 28, 2004 | 05:08 PM
ImAcracker's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS &raquo;</TD></TR><TR><TD CLASS="quote">The thing i dont get is, why is my PGM-FI Main Relay clicking off? When it clicks off for a split second, that's when it hiccups. Could the relay be going bad? or is there something else causing it?</TD></TR></TABLE>
Someone on the Uberdata forum was having that exact same problem. Look around over there. I dont remember the thread. If I happen to run into it Ill send you the link.
Old May 29, 2004 | 06:01 AM
JDubya's Avatar
That was me
Old May 29, 2004 | 08:31 AM
Only time I see the main relay acting like a baboon is when you either have a bad ground, or I plug in a certain speshul P75 ECU I have... dunno the how/what/why of it, but when I socketed the ECU it got itself proper fucked.
Check grounds, tighten them anyway even if they look/feel tight, and try a different ECU.
Old May 29, 2004 | 08:33 AM
JDubya's Avatar
Default Re: (J. Davis)
yea i was thinking about the ECU. Right now i'm running a P06 w/LS program. I'm trying to find a P74/75 at a decent price...
another thing. Does anyone have a really weird idle? When the car is cold it idles up around 2500-3K and just goes back and forth between the 2. As the motor warms up, the range gradually drops and eventually it gets a normal idle.
Old May 29, 2004 | 09:00 AM
GDM Z28's Avatar
i have my .bin from when i was tuned on 450's. i dont know if its gonna help but you could try it. i ran a smaller turbo though. I can add some fuel to it and see if it helps.
tweekerz
Nov 7, 2006 10:24 AM
importfan2
Feb 25, 2005 05:08 PM
turboed_teg
Aug 18, 2004 07:12 PM
TurbothisLS
Nov 14, 2002 06:34 AM
ElectronVTEC
Feb 18, 2002 04:36 PM
