Uberdata vs Hondata
Old Apr 28, 2004 | 02:44 PM
  #126
keebler65's Avatar
Default Re: (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Before you jump on the Willems, check out the USB burner at Moates.net. It's USB so no big ol' serial cable and no external power source, plus there's no need to short pins to burn 29c's. I had a Willem's, crapped out on me, jumped on this new burner for $85 shipped and it's definatley a more convienient unit IMO.
i will second this suggestion if you're unsure or not familiar with the moates burner, check out the 3 or 4 page thread in general discussion on the uberdata board.
Old Apr 29, 2004 | 12:07 AM
  #127
Cyphear's Avatar
Sounds like a good deal to me, especially for the not so electrically smart people on here.
Old Apr 29, 2004 | 01:04 AM
  #128
liam821's Avatar
25 Year Member
Default Re: (Cyphear)
Cool thead lots of good info!
liam
Old Apr 29, 2004 | 06:25 AM
  #129
blackeg's Avatar
Default Re: (liam821)
i got my moates in the mail the other day. its small, and easy to use thanks to the usb port connection .
Old May 7, 2004 | 05:54 PM
  #130
euclid's Avatar
Default Re: (blackeg)
will uberdata allow me to disable vtec pressure switch for use with JDM motor?
Old May 13, 2004 | 01:37 PM
  #131
ce's Avatar
ce
Default Re: (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">
haha ur right.
I wrote that wrong. I meant they all do the same thing in the end pretty much. (let you controll fuel and timing) But one does it a little better than the other I see.
I've got that that same damn problem with the hack right now actually. The vac cutoff, when I try to hold a consistent RPM..after like 3 seconds, the RPM's drop a ton. </TD></TR></TABLE>
Same problem for me..Except I run Hondata..So I guess it's not an Uberdata error
Old May 13, 2004 | 02:31 PM
  #132
keebler65's Avatar
Default Re: (ce)
yeah i've had that same problem with both my SMC+ as well as uberdata. its a sign from honda that we're supposed to keep our cars stock.
Old May 13, 2004 | 03:19 PM
  #133
badCRX's Avatar
New User
Default Re: (keebler65)
I posted in another Uberdata thread, but hopefully someone here will help. Is the Moates burner compatible with the Hondata software and hardware?
Old May 14, 2004 | 11:35 AM
  #134
ce's Avatar
ce
Default Re: (badCRX)
if it can burn a 29c256 flash PROM or similar it's fine. You don't have to use the Hondata ROMeditor to burn the chip.
Even though I have the Pocket Programmer that came with hondata, I prefer to use the separate software that came with the burner to make the chips..I like it better..
Old May 14, 2004 | 02:06 PM
  #135
Cyphear's Avatar
Default Re: (euclid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid &raquo;</TD></TR><TR><TD CLASS="quote">will uberdata allow me to disable vtec pressure switch for use with JDM motor?</TD></TR></TABLE>
There is a check box for VTEC coolant check, and PA sensor, im not sure what the PA sensor is... Maybe its what you want...
BadCRX, like the other guys said, you will be fine with any burner.
Old May 14, 2004 | 02:28 PM
  #136
uptownrickyv's Avatar
I just went to moates.net to order a burner... "out of stock until 5/25" Not that, thats far away... just thought i'd let everyone else on here know.
Old May 14, 2004 | 02:38 PM
  #137
project dc2's Avatar
are any of you guys having any drivabilyt problems at all ?
Old May 14, 2004 | 02:41 PM
  #138
Default Re: (project dc2)
On uberdata's site which version do i download? 1.65 original? repack? 2? 3?
Old May 14, 2004 | 02:46 PM
  #139
Cyphear's Avatar
Default Re: (uptownrickyv)
Download 1.66, i think you need to go back a page. Note, maps from 1.65 will load, but are not "correct" because of a map scalar change in 1.66.
TwinCityTuner
Mar 27, 2010 09:50 AM
5lugSlug
May 21, 2006 09:38 AM
CivicB18C1
Oct 18, 2005 08:23 PM
ice-burg-slimm
Dec 6, 2004 12:41 PM
