uberdata vacuum problem
Old Nov 15, 2003 | 04:53 PM
InTeGrA B18b1's Avatar
Default uberdata vacuum problem
i just chipped my p06 for the uberchip and it idles way better than the vafc hack. The problem is that when i gas a little bit the vacuum goes from -18 to -10 and starts to hesisitate. Little gas and the vacuum goes up like im in full throttle. My question is what is the problem? you think a restrictive exhaust could cause hesistating? thanks guys
Old Nov 15, 2003 | 05:00 PM
Mr. Softee's Avatar
Default Re: uberdata vacuum problem (InTeGrA B18b1)
make sure your injectors are scaled correctly... sounds strange-possibly tip in / tps related. you dont have wideband access do you?
Old Nov 15, 2003 | 05:05 PM
Default Re: uberdata vacuum problem (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">make sure your injectors are scaled correctly... sounds strange-possibly tip in / tps related. you dont have wideband access do you?</TD></TR></TABLE>
no i dont have access to a wideband. i am actually running your bin, dyno8. Tps related? what could i do? oh yea have stock exhaust on and could a small exhaust cause hesisitation?
Old Nov 15, 2003 | 05:09 PM
Mr. Softee's Avatar
that is strange, i had no such problems with my bin. I have no idea the stock exhuast could be richening it up, that bin was for 3" open downpipe on 91.
Old Nov 15, 2003 | 05:24 PM
im running 2.5 dp with a stock exhaust and 93 gas. YOu think im really rich? maybe i should try open dp to see how it runs.
Old Nov 15, 2003 | 05:38 PM
Mr. Softee's Avatar
to be honest im not sure. Is it when you give it gas from not having gas it hesitates? That sounds tip in related
Old Nov 16, 2003 | 06:42 PM
sporkcrx's Avatar
People with the OBD-0 chipped ecu's are having hesitations at 10 and 0 I believe. So if you guys figure out the solution let us know!
b20vtech
Aug 30, 2008 09:09 PM
computer07
Apr 1, 2008 07:40 PM
l e o h j
Apr 21, 2006 06:52 PM
kim_2_da_chee
Feb 17, 2005 11:05 PM
TurboSedan
Dec 23, 2004 05:18 AM
