SOHC 10.0.1 compression + turbo? quick or boom?
Just wondering anybody out there running high compression turbo in their sohc? Does this help on your spool if you have a big turbo? this pistons come out 10.2.1, I been searching on it most people say it can be done with good tunning, but nobody actually has one running that I know off what you guys think? All input will be appreciated trying to decide what compression to go with? I really would like to go with the high compression just because I havent seen it done with sohc!!!
Modified by booscivic at 6:30 PM 11/16/2003
Re: (booscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">I have Hondata</TD></TR></TABLE>
Youll be totally fine with a good tuner. What turbo are you going to run??
Re: (booscivic)
I would do it w/ Hondata or standalone. 10.1 is only a little higher than normal. People boost stock Rs and whatnot. I would just get rods and 10.1 pistons and a nice HG. That would probably support enough power for a street car. Well over 300 i'm sure
What size turbo?
What size turbo?
Re: (booscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">12-15psi track day maybe more!!!</TD></TR></TABLE>
My built block is 9.8 to 1. SOHC VTEC.
Re: (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">
My built block is 9.8 to 1. SOHC VTEC.</TD></TR></TABLE>
How many engines do you have? Yesterday you were talking about the stock d16 running 13psi. I need multiple engines
Re: (Marauder)
i ran 10psi on my 10:1:1 b16a block. thats the stock comp and it boosted very well. u won;t need 115 octain gas but i would try and find 94 octain instead of 93 for an added security. maksure to get colder plugs, ngkbrk-7's worked great in my b16a, and makesure your timming is retarded. should be a killer setup tho. i love higher comp wth boost.
Re: (Pfieffdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog »</TD></TR><TR><TD CLASS="quote">
How many engines do you have? Yesterday you were talking about the stock d16 running 13psi. I need multiple engines </TD></TR></TABLE>
stock block on 13 psi
Built Block waiting to go in.
Re: (booscivic)
We're running 28psi on 10:1 but it is a sleeved B series. We run 17psi on the street and 93 octane, and 93/C16 at the track. You should be fine. Find a good tuner and go for it.
