to turn up boost or not? help
Old Jul 10, 2004 | 10:02 AM
b18c1wes's Avatar
Default to turn up boost or not? help
i have a manual turbo xs boost controller that isnt installed on my car.. i have a tial wastegate with 5psi spring... my question is should i turn up the boost and if i need to do anything else besides install the boost controller. my car is a everyday driver engine is stock with about 50k miles i have never turned the boost past 5psi is it safe for me to do this.... the most i want to go for now is 8psi i was thinking 7 would be good though....
Old Jul 10, 2004 | 10:03 AM
b18c1wes's Avatar
my mods are listed above...
Old Jul 10, 2004 | 10:33 AM
wenlyone's Avatar
b18c1 jdm... what is the compression on that?
Old Jul 10, 2004 | 01:16 PM
b18c1wes's Avatar
i think its 10.5 to 1 its rated 10hp more than the usdm
Old Jul 10, 2004 | 01:30 PM
tyflip2's Avatar
Default Re: (b18c1wes)
i just got my jdm gsr tuned for 10psi
Old Jul 10, 2004 | 02:00 PM
b18c1wes's Avatar
stock internals ty>?
Old Jul 10, 2004 | 02:15 PM
AlphaKennyWun's Avatar
did you upgrade your injectors?
Old Jul 10, 2004 | 03:05 PM
b18c1wes's Avatar
no
Old Jul 10, 2004 | 03:15 PM
SpdFrk's Avatar
Default Re: to turn up boost or not? help (b18c1wes)
I wouldn't do it without getting bigger injectors and changing that fmu for an EMS and to getting it properly tuned. IMO.
Old Jul 10, 2004 | 03:17 PM
b18c1wes's Avatar
then i guess my question is ive been running my setup for awhile now and i wont have money for hondata and dyno time for awhile so is the diff from 5-7 psi 5 being what i run now going to hurt anything
Old Jul 10, 2004 | 03:25 PM
SpdFrk's Avatar
Have u tuned your motor for 5psi?
EDIT: Not necessarily dyno tuning but road tuning?
Old Jul 10, 2004 | 03:42 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1wes &raquo;</TD></TR><TR><TD CLASS="quote">then i guess my question is ive been running my setup for awhile now and i wont have money for hondata and dyno time for awhile so is the diff from 5-7 psi 5 being what i run now going to hurt anything </TD></TR></TABLE>
Ask yourself this. If you blow up your motor (not very likely unless your setup is REALLY screwed up) will you have money to fix your motor? I'd say just run it the way it is now and save up to get it done right. 7 psi more than likely won't mess anything up but you're pushing your luck with stock injectors and boost. Just my $.02
rickturboteg
Aug 28, 2006 05:36 PM
G-Phi
May 13, 2005 02:37 PM
ochsy03
Mar 24, 2005 08:53 AM
freeplay
Sep 4, 2003 06:38 PM
dwilson
Jan 23, 2003 09:48 AM
