manual or electronic boostr controller?
Old Dec 17, 2005 | 01:02 PM
chrisgottigsr's Avatar
Default manual or electronic boostr controller?
which boost controller is better or more reliable for running high boost. a manual or electronic boost controller. also are dual manual boost controllers any good?
Old Dec 17, 2005 | 07:17 PM
ek_chris's Avatar
Default Re: manual or electronic boostr controller? (chrisgottigsr)
electronic.
Old Dec 17, 2005 | 07:44 PM
mrbsponge's Avatar
Default Re: manual or electronic boostr controller? (ek_chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_chris &raquo;</TD></TR><TR><TD CLASS="quote">electronic.</TD></TR></TABLE>
bad answer with no explanation!
i used a manual boost controller for years, i thought they were just the best at rock solid boost regulation, until i had a friend with a bigger turbo and was able to spool it faster than mine, the reason was his blitz SBC-iD. an electronic boost controller will bring in boost usually 500rpms quicker by enabling the wastegate to ramp the amount of pressure it lets out and therefore allowing the motor to spool a bit kwiker and he turbo as well.
if you can spare the change get an electronic, if not use a good manual till you can get one
Old Dec 17, 2005 | 07:57 PM
ek_chris's Avatar
lol. i should of explained. If you are going to be switching from low to high boost I would recommend an electronic. If you are going to stick at high boost, set your MBC do "x" psi and leave it.
Old Dec 18, 2005 | 05:00 PM
TheThiefTheKnife'NTheGun's Avatar
Default Re: (ek_chris)
If you are looking for a man boost controller I have a brandnew turbo xs dual stage
Professor_X
May 9, 2011 07:53 PM
RedlineMotive
Nov 7, 2010 09:20 AM
eg:R
Nov 24, 2005 11:03 PM
