Wires ripped out of plug on boost controller, what to do???
Old Feb 22, 2008 | 03:39 PM
B20EF's Avatar
Default Wires ripped out of plug on boost controller, what to do???
The wires that come from the boost controller ripped out of the plug that attaches to the plug for the valve. It doesn't look like I can just pull the plug apart and put them back in, so can I solder them back in? Or cut the red and black wires to just directly connect the wires together with electrical tape or solder the, either way? Any Ideas, thanks.
Old Feb 22, 2008 | 03:48 PM
Bailhatch's Avatar
Default Re: Wires ripped out of plug on boost controller, what to do??? (B20EF)
You can buy almost any eletrical plug and new pins for it...just have to figure out which one you have and the pinout for it. If you can get the pins out without damage and know where the wires go, just solder them on and clip the pins back in. Or just solder them together when you install it...
Old Feb 22, 2008 | 03:52 PM
B20EF's Avatar
^^Your last comment, are you saying just solder the wires together directly, cause that would be easiest
Old Feb 22, 2008 | 04:14 PM
Tippyman's Avatar
Default Re: (B20EF)
You could just solder the wires together, but then you could never unplug it.
I would just go to the junkyard, and find any two pin connector. Cut it off, leaving like three inches on either side. Then just use that in place of the plug you currently have.
Old Feb 22, 2008 | 04:20 PM
inspyral's Avatar
You could also use male/female electrical spade connectors.
Old Feb 22, 2008 | 04:30 PM
Kyle R's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">You could also use male/female electrical spade connectors.</TD></TR></TABLE>
+1
Old Feb 22, 2008 | 04:38 PM
Bailhatch's Avatar
Default Re: (B20EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20EF &raquo;</TD></TR><TR><TD CLASS="quote">^^Your last comment, are you saying just solder the wires together directly, cause that would be easiest </TD></TR></TABLE>
yes thats what I meant. You can find all sorts of 2 wire plugs for sale at electronic supply stores too, if you want it to look a little more professional. like these;
http://cgi.ebay.com/ebaymotors...ZWD1V
Old Feb 22, 2008 | 04:42 PM
B20EF's Avatar
Thanks for the replies, this seems like an easy fix for me
Old Feb 22, 2008 | 04:44 PM
adrian1281's Avatar
Default Re: (Kyle@KR-TFab)
go to radioshack and get some male/female connectors like this one, they come with pins...
http://www.radioshack.com/prod...earch
you can crimp the wires into the pins with needle nose, but i would put a little solder onto it just to be safe. the pins slide into the connector easily and lock into place by themselves.
GsDAteg
Oct 7, 2007 12:58 PM
tegasaurus
Mar 5, 2004 06:53 AM
Acc91ord
Mar 3, 2002 05:54 PM
