TurboXS boost controller
Old Apr 16, 2002 | 06:12 AM
LEON's Avatar
Default TurboXS boost controller
I see from several other posts that the majority of the people here are using the Profec B or the Avc-R. Is anyone using a Turbo XS manual boost controller? I'm thinking of getting the TurboXS HP dual controller... is there any downside to using this other than the initial boost dial in?
Old Apr 16, 2002 | 09:00 AM
LEON's Avatar
Default Re: TurboXS boost controller (LEON)
anyone?
Old Apr 16, 2002 | 09:03 AM
falcongsr's Avatar
What is this crap?
it looks a lot like the gas flow regulators i saw at Lowes in the welding equipment section.
Old Apr 16, 2002 | 09:14 AM
*Boostwerks*'s Avatar
DO NOT GET THE XS. Not that it's a bad unit, it's just that you can make a custom one for WAY less.
$hit. I wish I had my links.
A place called "dawes device"(I think that's right) sells a solenoid, and boost controllers, to make a dual controller. Just search for the name. If you can't find it, I will post the link when i get home.
But the total cost of the controler is around 60 bucks.
Old Apr 16, 2002 | 09:30 AM
falcongsr's Avatar
What is this crap?
Default Re: TurboXS boost controller (Bryson)
its dawesdevices.com
i found the valve they were using on here and ordered 2 of them for $9 each.
Old Apr 16, 2002 | 10:57 AM
HENRY's Avatar
New User
I have the regular Turbo XS manual boost controller and I can say it's worth it. I do have a bit of a boost spike under hard acceleration but by only about (.5 to 1 psi). But it holds constant boost after that. I figured that's what you expect from all MBC. Got mine pretty cheap and I didn't want to fiddle with making one. I would recommend their products.
Old Apr 16, 2002 | 12:35 PM
SIK IN DA HED's Avatar
New User
Default Re: TurboXS boost controller (HENRY)
profecB u can read the boost adjustments in the car... mbcs are not as reliable.
Old Apr 16, 2002 | 12:56 PM
tonydatyga's Avatar
The places I see selling the TurboXS mbcs are a bit shady... they have them right next to the "generation 14 hyper super euro carbon look Sir-T type gtR altezzas". If you're gonna go mbc, I don't see a need to spend the $$ to go w/ a "name brand" b/c it seems they're all just as dependable or undependable (however you see it). If you don't mind some spiking. Course thats just my opinion so don't take it as anything more.
Old Apr 16, 2002 | 01:48 PM
dust's Avatar
Default Re: TurboXS boost controller (falconGSR)
ahem, care to share the source for those $9 valves?
Old Apr 16, 2002 | 02:28 PM
Smashback's Avatar
Default Re: TurboXS boost controller (tonydatyga)
Why don't you ask the guys that blew up their engines running some piece of junk that was put together from $1 worth of parts at the hardware store. Not that everybody has problems with them, but why risk it? If you don't want to spend the money on an electronic (or don't have the money to blow, like me) get the TurboXS High Perf manual boost controller. Lots of people use them, not just Honda guys, and love them. I know I love mine! Holds the boost rock solid every time and allows perfect adjustment. Basically one turn of the coarse adjustment screw gives you 1 PSI of boost. I just cranked mine up from 4.8 to 7.2 PSI this weekend. Muuuuuch better
Oh yeah, if you don't mind the spiking? Dude, what happens when you're running 8 PSI and it spikes to 16...doh! Well, at least you saved 50 bucks on your boost controller that you can use for the $1000+ engine rebuild you'll need
[Modified by mplex2000, 11:29 PM 4/16/2002]
Old Apr 16, 2002 | 02:33 PM
12 oz.'s Avatar
Default Re: TurboXS boost controller (mplex2000)
turbo XS dual stage boost controller, simple and no fluctation.
i have heard nothing but good comments about it.
Default Re: TurboXS boost controller (dust)
Look at falconGSR's post, and mine even.
It's http://www.Dawesdevices.com
It's not 9 bucks, but 35 isn't bad for a simple device that will work.
[Modified by Bryson, 3:35 PM 4/16/2002]
Old Apr 16, 2002 | 03:43 PM
littlebluecrx's Avatar
I like it works great for me, real easy to use and quick to install, no creep with good wastegate, Jason
Old Apr 16, 2002 | 05:17 PM
LEON's Avatar
Default Re: TurboXS boost controller (littlebluecrx)
Thanks for all the replys. I am really interested in the TurboXS HP DUAL (not the single base one). I was/am concerned about boost spikes and would rather spend the extra money for an electronic if that's the case, but it sounds like a lot of people have had good experience with this piece and by the sounds of it it holds boost pretty solid with no spiking.
Those that have used the TurboXS.... have you noticed if your turbo really spools up a little quicker?
Old Apr 16, 2002 | 06:03 PM
biassj's Avatar
I have a the XS Dual Stage, constant boost...
Old Apr 16, 2002 | 07:46 PM
falcongsr's Avatar
What is this crap?
http://www.xmission.com/~dempsey/perform/grainger.htm
i ordered it from McMaster. follow the link.
i havent tried this thing. use at own risk.
beamer
Feb 22, 2016 08:07 PM
Silentxracer
Texas -OK -LA (Sales)
Mar 21, 2010 12:36 PM
yisoulja
Apr 14, 2003 09:30 PM
mikelcrx
Jul 4, 2002 10:20 PM
