Turbo xs bov question
Old 04-21-2009, 12:50 PM
holsetcivic's Avatar
Default Turbo xs bov question
im in the market for a good bov for my civic, soon to be turboed with a holset hx30. i plan on using a tial 38mm wg, and would like to use the turbo xs type h-rfl bov also. the problem is the description for the bov says good for between 10-25psi. i only wanna run 6-8psi, would there be any compressor surge issues if i ran the turbo xs bov or any other issues by running lower than suggested boost?
blow off valve link: http://store.summitracing.com/partde...5&autoview=sku
thanks for any advice
Old 04-21-2009, 01:35 PM
malink's Avatar
Default Re: Turbo xs bov question
your fine,
I ran the same bov on my setp at 8 psi with no problems. I also have an holset...hx35w )
By the way, its ****ing loud but i like it
Old 04-21-2009, 02:10 PM
Originally Posted by malink
your fine,
NICE! thats great news, cause i want a really loud bov.
also, around what rpm's does your hx35 build peak boost(8psi)?
Old 04-21-2009, 02:53 PM
malink's Avatar
around 4800-5000...full boost
but i do have a h22...motor likes to breathe
Old 04-21-2009, 03:51 PM
Silva Bullit DC4's Avatar
your fine,
I had one @ 9 psi on a 50 trim Borg Warner, and it was annoying IMO. I got rid f it. But if you want the WHOLE WORLD to know you're running boost, THATS the bov to get, lol! ;-)
Old 04-21-2009, 06:26 PM
Joeski99Si's Avatar
im using the turbo xs BOV on 8psi, works fine . it is loud everyone will hear you !
Old 04-21-2009, 06:52 PM
Moderator
TheShodan's Avatar
And it will blow off after every downshift, upshift, and change of throttle position. I'm glad I got rid of it. Also got tired of re-lubricating the piston every couple of weeks because it would stick open..
Good riddance.
Old 04-21-2009, 07:44 PM
malink's Avatar
do any of you guys know a blow off that doesnt make noise. Its would be perfect for my sleeper...just the sound of the turbo spooling
Old 04-21-2009, 08:49 PM
Moderator
TheShodan's Avatar
Only a recirculating valve would do that, such as a DSM flanged valve (under 14psi), or a TiAL Alpha Q that is recirculated.
slide inside
09-24-2009 08:40 PM
superslow-oto
10-27-2007 05:34 PM
MiKeAhOwSkI
10-13-2005 06:02 PM
DownBoyDown
02-02-2004 09:19 AM
n*hance*ek
12-05-2002 09:51 PM
Quick Reply: Turbo xs bov question
