Hondata MAP Sensor question
Old Jun 24, 2002 | 11:58 AM
The_Head's Avatar
Default Hondata MAP Sensor question
If you upgrade from a 2 BAR to a 3 BAR MAP sensor without telling the Hondata unit in the ROM editor, what will happen? The guy I sold my car to did just that and he has been getting CEL's but the code thrown is invalid.
BTW, this guy has been boosting 15+ psi on 440 cc injectors, when the car was tuned and dynoed, it was maxing out the 440's on 10 psi, tuning for a 12.2:1 A/F ratio. Smart guy eh?
Another thing, when the car was tuned, the boost cutout on the Hondata was set for 11 psi, since the different MAP sensor gives a different voltage for 11 psi, maybe thats how he is able to go past 11 psi and not hit the cutout?
Old Jun 24, 2002 | 12:01 PM
VaporTrail's Avatar
New User
Default Re: Hondata MAP Sensor question (xThexHeadx)
the voltage changes with the 3 bar, and therefor, his tuning will be just about worthless. The Hondata unit has to be told there is a 3 bar attached, otherwise it cannot compensate correctly.
Old Jun 24, 2002 | 12:08 PM
dustin's Avatar
Default Re: Hondata MAP Sensor question (VaporTrail)
The thing with hondata is that you can technically run /any/ map sensor and still tune for it. Just understand that 0v is full vacuum and 5v is the top limit of the sensor, it should be linear between those 2 points.
Dustin
Old Jun 24, 2002 | 12:49 PM
The_Head's Avatar
Default Re: Hondata MAP Sensor question (dustin)
...so 5 Volts on the 2 bar ~ 11 psi, where the Hondata boost cutout is supposed to kick in... but I guess the 11 psi voltage on a 3 BAR MAP sensor would be less that that, so is that why he can go past 11 psi? Sounds like the Hondata thinks its seeing a certain boost but the actual boost is somewhat higher, so the motor is probably not getting the fuel required for the boost he's running I'm debating on if I should tell the guy, he's kind of a cocky fella
Old Jun 24, 2002 | 12:51 PM
dustin's Avatar
let him blow it up hehe.
But yeah, if he doesn't have the ROM set to 3bar then it will boost past the boost cut.
Todallybuilt
Engine Management and Tuning
Oct 15, 2017 06:18 AM
b20turbocivic
Aug 12, 2010 07:06 PM
oemDC2
Jan 5, 2004 09:45 AM
