Turbo Trim For B18c1
Old Nov 20, 2002 | 05:51 PM
VtecInteg95's Avatar
Default Turbo Trim For B18c1
Im gettign a garret t3/t04e turbo, i was thinking about getting it with 57 TRIM W/ .63 A/R TURBINE.. Anyone know if this is a good size for my motor... if not what would oyu guys suggest.. bigger smaller..any opinions or facts will help.. let me know asap so i can order... Thanks
GARRETT T3/TO4E 60 TRIM W/ .63 A/R TURBINE Too big...???
both turbos with stage III turbines
Old Nov 20, 2002 | 06:00 PM
Flamenco-T's Avatar
Default Re: Turbo Trim For B18c1 (VtecInteg95)
57 is perfect....
there are a lot of guys here that makes a lot of power 300 plus on less than 10 psi with that setup...
I made 256 at 6.5psi with 54 trim....
Old Nov 20, 2002 | 06:10 PM
Boostfed's Avatar
New User
Gotta know more, What type of redline and what kind of boost and horsepower goals? 57 trim is still somewhat big but almost universal like a 54 trim too, in reality sometime T3/T04B have good spec turbo too like a Super V wheel is very good and comes in alot of kits, good spool and goo top end too. It all depends on your set up and goals. Let me know, Redline, Boost Level, Displacement. I'll do the compressor maps for you, or call Turbonetics or Innovative Turbo and ask them, even if you are going o get a Garret from a diff distribuotr, use your resources.
Old Nov 20, 2002 | 06:20 PM
Default Re: Turbo Trim For B18c1 (Boostfed)
Max 9 psi (higher in distant future after rebuild for low compression)
Stock Internals
8k redline (want the turbo to be effecient till 8k at least)
let me know what you think, your opinion really does matter, cause i need to order this thign asap... thanks
kyle
Old Nov 20, 2002 | 06:30 PM
Boostfed's Avatar
New User
I'm really thinking a 54 trim, .63 A/R Turbine with a Stage III wheeel, I think the 57 trim may be getting too big since you will not boost alot and running real high rpms, even a 50 trim would work. But remeber you say 8k rpm and 9psi now, later it will 18psi and 8500rpms So I feel run big for more potential in the future. A 57 or 60 trim would be good and if you think you want 400+ then T3/60-1 definately. HTH
Old Nov 20, 2002 | 06:34 PM
well if its a tado n the larger side itsn to a problem.. any ideas on when it might be fully spooled by? thats the major concern is turbo lag.. i know no matter hwat im gonna have it but i just dotn want too much.. Let me know..thanks
Kyle
effiecency range isnt a problem.. is it?
Old Nov 20, 2002 | 06:37 PM
Boostfed's Avatar
New User
All depends also on your downpipe size, efficiency of your manifold, headwork, Compression ratio is a big factor too. But this is stock right? Stock GSR start boostin low 3k rpms and full boost by at least 4k rpms, Pull strong all the way to redline. Once you start boosting the FF breaks loose. :D
Old Nov 20, 2002 | 06:48 PM
sweet man.. i think i will go with that turbo.. not makin a mistake am i? this is a rather large investment to me at thsi time... haha.. thanks
Kyle
1JDMDOMINICAN
Dec 28, 2004 07:55 PM
crxsir23
Jul 21, 2004 06:23 PM
bluedelsol
Jun 14, 2003 11:37 AM
95lsteg
Mar 26, 2003 05:14 PM
InfamousRS
Dec 16, 2001 01:47 AM
