i need a young priest and a old priest, TURBO PROBLEMS PLEASE HELP!!!!!!
I just started my turbonetics kit for the first time on my 00si and the car won't run right. It stays in limp mode(i think) I checked my o2 sensors and my wireing At first i pulled the wires out of the new map sensor and the car ran ok and then it wouldn't run right and then i read i needed to run my mf2 on a different impulse wire than the MSD boost timer. so i did and it ran right with everything connected, wah-lah everything is good, oh nevermind started it again and back in limp mode. any suggestion are welcome
Re: i need a young priest and a old priest, TURBO PROBLEMS PLEASE HELP!!!!!! (Benjithx)
bump!!!
for real guys this is ****'n with my head, i tried resetting the ecu, no help. does anyone know how to check the code on a 2000si.
Grab a multimeter and test the voltage outputted by the MAP sensor. Bets are that it is seeing boost.
Re: i need a young priest and a old priest, TURBO PROBLEMS PLEASE HELP!!!!!! (beepy)
which map sensor stock over the missing link or the new one that runs the mf2?
bump get'r'done boyz let me know what to do, how to check it and in detail because i am just dumb enough to **** up an easy *** kit like this one... for shame....for shame
the mf2 unit is a piece of junk, i haven't seen anyone with success in using that controller.
but the problem with the limp mode is that ur map sensor is seeing boost. did you try using a missing link?
