Turbo spining
Old Oct 24, 2001 | 02:28 PM
GSRacer's Avatar
New User
Default Turbo spining
ok my turbo doesn't sping sometimes when the car is idling. Is this normal??
Old Oct 24, 2001 | 02:29 PM
TurboInteg95's Avatar
Default Re: Turbo spining (GSRacer)
yeah, that is normal
Old Oct 24, 2001 | 02:57 PM
GSRacer's Avatar
New User
Default Re: Turbo spining (TurboInteg95)
thanks. i was told that there was something wrong with my turbo if it didn't spin at idle
Old Oct 25, 2001 | 08:34 AM
Doodoo's Avatar
Mine did that too. Just stopped after about 15-20 minutes of idling. Scared the shitt out of me!! But I called majestic and clamed me down, normal.
I would think if it stopped spinning and when you hit the throttle it doesn't start immediatly, you would have a problem.
Old Oct 25, 2001 | 10:21 AM
rtype11's Avatar
its okay if it doesnt spin, especially with conventional bearings, but just to make sure check oil pressure to turbo, idle keeps oil psi low, at 1500rpm you have a lot of pressure and the turbo should spin very fast, partially because of amount of exhaust but mostly from extra oil pressure lifting the turbo shaft onto and oil film.
Old Oct 30, 2001 | 09:19 AM
GSRacer's Avatar
New User
Default Re: Turbo spining (rtype11)
makes me wonder
Old Oct 30, 2001 | 09:44 AM
Muckman's Avatar
Moderator in Chief
how do u know if its spinning or not. you cant possible hear it at that low of rpm.
i thought turbos always were spinning as long as the engine was on.
Old Oct 30, 2001 | 09:46 AM
Rob03Pro5's Avatar
Default Re: Turbo spining (Muckman)
you take off the intake piping and filter! At idle, the exhaust is barely making enough air to push the turbo's turbine.. this is different tho on BB turbos and turbo's with smaller wheels.
Old Oct 30, 2001 | 12:28 PM
DLB1994's Avatar
Default Re: Turbo spining (Rob92SC)
mine spins at idle most likey its because h23 big motor
nihad
Nov 30, 2008 06:40 PM
CRXdan
Nov 23, 2007 06:52 PM
97grnrs
Feb 6, 2006 06:50 AM
Johnny_Rocket
May 6, 2005 09:26 PM
nortel
Feb 11, 2003 12:33 PM
