Turbo SOHC fuel correction help
Old May 28, 2008 | 11:07 AM
kauai96's Avatar
Default Turbo SOHC fuel correction help
I was wondering what i should do for fuel correction on my d16 im currently turbocharging. I was hoping to just get away with an apexi S-AFC, and possibly a fuel pump? now would that be enough? or would i be running too lean? any info or help on just turbo and fuel correction on similar setups is welcomed.
Old May 28, 2008 | 11:15 AM
kauai96's Avatar
oh yeah , i forgot im trying to not replace the computer at this moment in time, thats down the line a little bit. Thank You
Old Jun 4, 2008 | 06:06 PM
d16y8turbo's Avatar
How much boost are you trying to run? With the stock injectors you cant really run much boost at all. Even running 6-7lbs you need to either up the fuel pressure with an FMU, or increase the injector size and lean them out with the afc. I ran 310's with a very mild greddy setup a long time ago and just leaned out the injectors with the afc. I also had a fuel pump tho.
Old Jun 4, 2008 | 09:05 PM
Boostfed86's Avatar
Default Re: (kauai96)
crome, ECTUNE, NEptune... Duude..
S/V-AFC- so 2002.
Old Jun 4, 2008 | 11:15 PM
kauai96's Avatar
Default Re: (Boostfed86)
thanks, i was definatly thinking injectors,but i think i fuel pump would be too much? for only like 6lbs, i just got a apexi SAFC neo.im hoping that will work out nice. i was also wondering about ignition, any bodys setups, ive only ever had MSD i was hoping sombody knew of a small kine cheaper company then MSD. and if i got the ignition, im thinking i would definatly have to do a fuel pump. thats as far as ive come, i have got my air/fuel ratio gauge and a boost gauge.also a little side note, i am looking to buy a turbo timer?!? k alohaz frm ct.
Old Jun 5, 2008 | 06:03 AM
Rwill's Avatar
ditch the neo.. junk when you can chip your ecu and tune with uberdata or chrome. for 6 pounds on a single cam get dsm 450 injectors, resister box. your stock fuel pump will be fine for 6 pounds.
Old Jun 5, 2008 | 06:04 AM
Rwill's Avatar
Default Re: (Rwill)
btw. what setup are you going with?
Old Jun 5, 2008 | 12:25 PM
Boostfed86's Avatar
Default Re: (Rwill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kauai96 &raquo;</TD></TR><TR><TD CLASS="quote">thanks, i was definatly thinking injectors,but i think i fuel pump would be too much? for only like 6lbs, i just got a apexi SAFC neo.im hoping that will work out nice. i was also wondering about ignition, any bodys setups, ive only ever had MSD i was hoping sombody knew of a small kine cheaper company then MSD. and if i got the ignition, im thinking i would definatly have to do a fuel pump. thats as far as ive come, i have got my air/fuel ratio gauge and a boost gauge.also a little side note, i am looking to buy a turbo timer?!? k alohaz frm ct.</TD></TR></TABLE>
Dude, Don't worry about the ignition, that ***** strong, way strong enough to support any 6psi set up on a D-series. And for your A/F ratio gauge, are you talking about an autometer or something? I hope not. Its not gonna do **** except go back and forth... For the money you're spending on this unnecesary stuff, you could have had someone chip and street tune the car already.
Old Jun 5, 2008 | 07:45 PM
kauai96's Avatar
thanks, i got the cheap *** ebay turbo kit (money wasted) and im shopping for a garret t3/t4. and also a new manifold u can just see how crappy the welds are, but im going to run the piping and intercooler. I was going to buy a motor but the ***** didnt tell me that it had a small hole in the block, so im lookin for a new SOHC longblock &lt; if anybody knows of one in CT&gt;to build up while i blow this one usin it as a test dummy. so well see how it ll plays out. you really think the neo is rubbish? does hondata do reflashes for d series? or what other good ones would you reccomend?
Modified by kauai96 at 9:19 PM 6/5/2008
Old Jun 5, 2008 | 07:46 PM
kauai96's Avatar
oh yeh im just planning on usin the apexi as a a/f gauge
Old Jun 5, 2008 | 08:25 PM
Rwill's Avatar
use chrome. i would stick to a stright t3 like one off of an older volvo. a t3 will be big enough for a d16 and a t3-t4 will suck for anything less then 10 pounds
Old Jun 5, 2008 | 09:05 PM
HiProfile's Avatar
Default Re: (Rwill)
The apexi unit costs as much as a decent street tune. The street tune nets you more power, as well as better gas milage and more safety. And YES there are tuners within a few hours drive from you. The gas you spend driving that far will be recouped after a week of blindly dumping extra fuel into the motor.
Its like fuking a girl. You have to buy flowers and dinner first, but it is TOTALLY worth the price of admission into the vagina, especially compaired to "other means".
Old Jun 6, 2008 | 02:21 PM
Boostfed86's Avatar
Default Re: (HiProfile)
Hate to bust your bubble, but it looks like you've dumped a lot of money into a bag of crap. Ebay turbo kits=Poop, Apexi Neo= Crap for honda tunes, T3/T4=no efficiency@6psi on a D. Go with something like a .42/.48 volvo/Saab Turbo. It would yield good spool, and decent power. I built a ZC a while back on the turbo above, 10 psi= 200whp Crome tune. Crome tune will yield soo many more benefits above the Neo. The only thing you'll lose is a cool screen to show your friends. Get tuned...
Old Jun 10, 2008 | 03:00 PM
kauai96's Avatar
tuned it is, i was wondering if anybody knows of a D16y7 or y8 in the in maine ,ct,ny,nj,ma,, that would be useful. any tips opn findin a good tuner?
alohaz
Old Jun 10, 2008 | 09:15 PM
nihad's Avatar
Default Re: Turbo SOHC fuel correction help (kauai96)
https://honda-tech.com/zerothread/1347699 you are welcome
Old Jun 17, 2008 | 01:45 PM
kauai96's Avatar
Default Re: Turbo SOHC fuel correction help (nihad)
thanks yo, aloha for da list
89efDUSTY
Dec 26, 2006 11:42 AM
bmoser18
Aug 16, 2005 02:30 PM
hot90honda
Jul 23, 2003 01:29 PM
2k1civicturbo
Jan 23, 2003 10:43 AM
spacemanspiff
14
Dec 30, 2002 09:27 AM
