fuel
Old Jul 23, 2003 | 12:00 PM
hot90honda's Avatar
Default fuel
i have 1.6 sohc with a greddy turbo at 7 1/2 psi it gets lean will a inline fuel pump solve my prob.
Old Jul 23, 2003 | 12:01 PM
TurboDANDEE's Avatar
Default Re: fuel (hot90honda)
nope, a pump will just give u better fuel delivery to the rail and injectors, it will not up the fuel its burning. i would suggest getting a regulator or going with a bigger set of injectors.
Old Jul 23, 2003 | 12:05 PM
hot90honda's Avatar
Default Re: fuel (TurboDANDEE)
WILL GSR INJECTORS WORK
Old Jul 23, 2003 | 12:08 PM
i believe they will flow more than SOHC injectors
Old Jul 23, 2003 | 12:17 PM
EE_Chris's Avatar
What else do you have as far as fuel management goes?
To get more fuel, you have to either a) turn up the fuel pressure or b) lengthen the injector on-time.
An inline pump, buy its nature, will turn the fuel pressure up only because the regulator your probably using can't return enough fuel volume to the tank, so pressure rises slightly....but you should not consider this 'turning up the fuel pressure'.
First suggestion is Hondata or some form of standalone engine management. Otherwise, your looking at an FMU setup or VAFC hack.
Didn't your Greddy kit come with a blue box? I thought those boxes ran rich as hell.
And correct me if I'm wrong: Civic/Teg injectors are all 240cc
Old Jul 23, 2003 | 01:29 PM
g2ls_turbo's Avatar
yes, all civic and tegs come pretty much about 240cc.
the intank pump like the walbro or the bbk 255 should bump up your fuel pressure by 9 or 10 psi. it will cause a little more fuel delivery and injection. mine cause a over rich start everytime.
fuel pump i dont think will solve your problem depends on when and what rpm it goes lean in, undr noost or no boost. the greddy like they say should have come with a blue box, it should be enough to keep your pretty rich.
JDM turbo DC
Nov 8, 2005 05:51 PM
spcmotorsports
Oct 9, 2002 05:24 AM
ZERO COOL
Jul 28, 2002 12:22 PM
Tripz
May 6, 2002 06:04 PM
sushibug
May 6, 2002 05:50 PM
