Turbo setup this weekend- Failed Bad - Need help please.
Old Oct 5, 2003 | 07:06 PM
kKdARIAN's Avatar
Vice President/CEO
Default Turbo setup this weekend- Failed Bad - Need help please.
Setup: D16Y8 - 1995 Honda Del Sol - Stock internals
Turbo - T04E .50 A/R Compressor, .63 A/R Turbine
Tubular manifold - Delta-mark II wastegate 9-13psi spring
FMU 12:1 w/ stock injectors
After i installed everything, connected the pipes to the intercooler, hooked up vacuum lines etc... I noticed a few things. When the car was idling, the intake turbine was not spinning, when i gave it gas, it spun. Oil lines hooked up properly, no leaks etc.
Problems:
1. Boost gauge showing ZERO boost when driving with kit installed.
2. Blow-off valve not functioning.
3. Waste gate not opening
Basically, i have the whole turbo kit setup and the car is running as if i have no turbo at all. Boost gauge shows vacuum, but when i give it full throttle, goes to 0 boost.
Disgusted, i took off my turbo kit and returned to n/a. I want this kit to work, i know im doing something wrong. Any help would be GREATLY appreciated.
I have some DSM 450cc injectors that i've yet to install, and a VAFC that has still yet to be hacked, but still at a loss as to why I am not boosting.
Is it possible that the turbo is too big for my setup?
If your in the Dallas area and can assist me in this install, that would be awesome.
ANy feedback or questions will be greatly appreciated.
Thanks,
Kenny
here are some pics of the turbo, it has a broken fin on the wheel but still spins freely.... ?
Here shows the chipped turbine that i chipped when clocking the turbo.
Modified by kKdARIAN at 7:29 AM 10/6/2003
Old Oct 5, 2003 | 07:20 PM
HXMan's Avatar
Default Re: Turbo setup this weekend- Failed Bad - Need help please. (kKdARIAN)
I would NOT use the turbo with a blade broke like that.
The speed that part spins at is so high that with it off balance like that it will probably explode.
Old Oct 5, 2003 | 07:21 PM
bigwig's Avatar
my guess is either you dont have the VAC lines setup right or its your deltagate which suck big hairy *****.
Old Oct 5, 2003 | 07:36 PM
FredoSP's Avatar
replace that wheel!!
Old Oct 5, 2003 | 07:38 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Turbo setup this weekend- Failed Bad - Need help please. (FredoSP)
ugh, i know i need to and WILL before i put it back on my car.
So this turbo is NOT to big for my engine?
Where can i get a new wheel from... ugh.. All the research i did never prepared me for the mishaps i had this weekend.
THanks for the input.
Old Oct 5, 2003 | 07:51 PM
99integralsturbo's Avatar
the reason the turbine didnt spin in idle was because the turbo is big the same thing happened um my friends 240 sx because the turbo was huge. also with a wheel like that it would destroy the whole turbo so replace the wheel talk to the manufacturer of the turbo for the replacement part
Old Oct 5, 2003 | 09:09 PM
rjardy's Avatar
Default Re: Turbo setup this weekend- Failed Bad - Need help please. (99integralsturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99integralsturbo &raquo;</TD></TR><TR><TD CLASS="quote">the reason the turbine didnt spin in idle was because the turbo is big the same thing happened um my friends 240 sx because the turbo was huge. also with a wheel like that it would destroy the whole turbo so replace the wheel talk to the manufacturer of the turbo for the replacement part
Most wheels wont spin at idle unless its a ball bearing. Any your BOV and wastegate not working, have to do with the fact that your turbo isnt making any boost. Fix that, and the others will work/should work.
Rob
Old Oct 5, 2003 | 09:25 PM
boostcrazy19's Avatar
make sure your intercooler piping isn't unhooked from anywhere
Old Oct 5, 2003 | 09:29 PM
Ri5e's Avatar
Default Re: Turbo setup this weekend- Failed Bad - Need help please. (turbosi19)
I've owned 4 turbos and all of them spin at idle. None of them were ball bearing...
Do you hear any exhaust leaks? Are all of the charge pipes tight? A small boost leak can cause you to have no boost. No boost = Wastegate and Blow off valve will not work ...
That manifold/turbo combo looks like the SSAutochrome stuff on Ebay....
Old Oct 6, 2003 | 04:28 AM
ekb18c's Avatar
not all turbos will spin at idle.
Replace the wheel of the turbo. Do not use a wheel that is broken.
Old Oct 6, 2003 | 04:31 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Turbo setup this weekend- Failed Bad - Need help please. (ekb18c)
So I am still thinking of blowing the whole setup up, selling it all.
Is the turbo setup too big for my engine? I don't want to give up, I just need to know if that turbo is too big. If its fine for my car, I will replace the wheel and try again.
THanks for all your input,
kenny
Old Oct 6, 2003 | 05:27 AM
HYBRID_H@TCH's Avatar
turbo size will be fine..just take a lil longer to boost thats all..and I have seen a few turbos that where like yours that would not boost due to the broken spot letting the pressure out before it could get in..keep it..buy a new wheel..and boost.
Old Oct 6, 2003 | 05:32 AM
nevin's Avatar
yeah dont give up your really close.
Old Oct 6, 2003 | 05:38 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">yeah dont give up your really close.</TD></TR></TABLE>
then its settled. I will buy a new turbine wheel today and go from there... thanks alot for the input...
kenny
Old Oct 6, 2003 | 05:55 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (kKdARIAN)
the turbo is the right size just check your piping, and wastegate. If you don't build boost, it's becuase your losing it from a different area.
My wastegate feel off.........(screws to short and backed out) don't laugh
IC piping poped off.....gauge read zero boost. I don't mind helping you on a weekend. Check your vac lines as well.....Im repeating everyone, sorry.
Old Oct 6, 2003 | 06:34 AM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN &raquo;</TD></TR><TR><TD CLASS="quote">
kenny </TD></TR></TABLE>
yeah, don't give up so easily..btw, if the turbo isn't spinning at idle than it's most likely trashed.
Old Oct 6, 2003 | 06:37 AM
Happyman's Avatar
Default Re: (HybridcivicLS-T)
On a d16 I would not use a t3/to4e. If I was you I'd downgrade to a T3 or T3 super 60. You probbaly won't see full boost on your car until like 5000 rpm. That's only 2200 rpms of boost. Good thing about it would be that you probably wouldn't spin too bad.
Old Oct 6, 2003 | 11:22 AM
Mr. Softee's Avatar
Default Re: (eh6turbo)
if you got no boost your piping blew off... plain and simple.
Old Nov 21, 2004 | 08:04 PM
Del_Slowest's Avatar
Default Re: (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">if you got no boost your piping blew off... plain and simple.</TD></TR></TABLE>
odd, if your wastegate flipper was open then it wouldn't boost either....right?
Old Nov 21, 2004 | 10:42 PM
calvinPGMFI's Avatar
Default Re: (Del_Slowest)
IC pipinh check that
night2
Nov 29, 2005 05:58 PM
marino1982
Jan 8, 2005 09:45 AM
MooreBoost
Aug 8, 2004 11:14 AM
crx1856
Aug 19, 2003 04:39 PM
Generation2
Jul 22, 2003 07:28 PM
