turbo setup
Old May 4, 2005 | 05:26 AM
88superrex's Avatar
Default turbo setup
can any help me out im turbo n my hatch and got a t3 t4 ,front mount ,and second gen blow off valve what else do i need and how much can i push to my d16 minie me
Old May 4, 2005 | 06:29 AM
Frozen E's Avatar
H-T White Ops
search and post your question in the Forced Induction forum.
Old May 4, 2005 | 06:41 AM
Ricey McRicerton's Avatar
Default Re: (IslandSi)
You need a turbo manifold, charge piping, some kind of a wastegate if that turbo you have does not have an internal, fuel management, and some way to tap your oil pan for the oil feed and return lines to get it up and running. I'd also recommend a boost guage before you ever boost. SCC blew up the car the first Edelbrock kit was on because of no guage.
If you're asking this question, a pre-fab kit may be the right thing for you. It's much easier, comes with instructions, and helps you learn a ton about F/I before you go out there building your own.
Old May 4, 2005 | 06:47 AM
Happyman's Avatar
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">You need a turbo manifold, charge piping, some kind of a wastegate if that turbo you have does not have an internal, fuel management, and some way to tap your oil pan for the oil feed and return lines to get it up and running. I'd also recommend a boost guage before you ever boost. SCC blew up the car the first Edelbrock kit was on because of no guage.
If you're asking this question, a pre-fab kit may be the right thing for you. It's much easier, comes with instructions, and helps you learn a ton about F/I before you go out there building your own. </TD></TR></TABLE>
Actually...oil feed will be tapped from the oil pressure sending unit...I'd go with a prefab kit though. The greddy is only 1500$ shipped and then you just need intercooler, bov, and gauges. All and all about 2000$ if you want to go cheap or 2500$ if you buy stuff new like I did. Search through Forced Induction. I bought my greddy kit and everything and researched for 6 months before doing the install.
Old May 4, 2005 | 06:50 AM
Frozen E's Avatar
H-T White Ops
Do LOTS of reading up. LOTS and LOTS.
Carson-EK9
Mar 16, 2006 07:53 PM
19sec beast
Mar 20, 2005 06:50 AM
mattduskater
Dec 13, 2003 09:41 PM
napester21
Aug 20, 2003 10:18 PM
AudioXtremes
Mar 26, 2003 05:17 PM
