turbo-set up what do you think?
Old 04-28-2005, 09:58 AM
94lsturboteg's Avatar
Default turbo-set up what do you think? INPUT PLEASE
this is my new setup (haven't driven it yet)
01 B18B
01 GSR tranny
act stage two heavy duty clutch kit
Skunk2 short throw
t3 turbonetics full kit
bar n plate intercooler (2.5" piping)
2.5" down pipe
Je Edelbrock 70mm tb
Skunk2 IM
Apexi n1 3" full cat
Msd 6al full ignition
fluidyne radiator (slim fans)
Spoon thermo
Apexi AVC R, AFC & turbo timer
AEM fuel rail, fpr, & ff
rc 550s
walbro 255 fuel pump
uberdata
urathane motor mounts
i think thats everything
I'm only looking for 250-270 whp IS THIS POSSIBLE
Modified by 94lsturboteg at 11:19 AM 4/28/2005
Old 04-28-2005, 10:05 AM
ncervantes's Avatar
Default Re: turbo-set up what do you think? (94lsturboteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsturboteg &raquo;</TD></TR><TR><TD CLASS="quote">uberdata
I'm only looking for 250-270 whp IS THIS POSSIBLE </TD></TR></TABLE>
UBERDATA!!! &lt;3 &lt;3 &lt;3 &lt;3 &lt;3 &lt;3 &lt;3
I think you should have no problems hitting 250-270 with that setup tuned.
Old 04-28-2005, 10:10 AM
Default Re: turbo-set up what do you think? (ncervantes)
do you think it will be reliable? I've delt with so much **** wih this car is there any other little thinkgs i can buy to ensure life of my motor? Besides a good tune
Old 04-28-2005, 11:29 AM
BoOsTeD C1's Avatar
the afc is not needed if you're running uberdata
Old 04-28-2005, 12:17 PM
ncervantes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_pWrD_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">the afc is not needed if you're running uberdata</TD></TR></TABLE>
yeah, lose the afc you won't need it with Uber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94lsturboteg &raquo;</TD></TR><TR><TD CLASS="quote">do you think it will be reliable? I've delt with so much **** wih this car is there any other little thinkgs i can buy to ensure life of my motor? Besides a good tune</TD></TR></TABLE>
With a stock motor, tuning is the key! Even though you are using Uberdata, you will still need to tune that bad boy. HAve projekteg from homemadeturbo.com do your base map(he's a pimp with uber). If you do that you should be fine for a long time.
p.s. the RC 550's seem a little over kill for your setup but I don't think that will be a problem.
Old 04-29-2005, 12:47 PM
uberdata was just a baseline tune so iwas going to use the afc to lean it out were its need and add fuel when needed! i live in upstate ny and i don't wana have to burn a chip for every new part i put on such as cams or whatever. should i lose the afc and get a wideband o2 to do this?
P.S. i went with 550s incase i deside to beef it up!!
Old 05-03-2005, 03:25 PM
ncervantes's Avatar
I wouldn't use an AFC to tune Uber. Find someone who can tune with uber or get a wideband and tune it yourself(if you know how to). Just my $0.02
jmac
01-30-2007 06:54 PM
Blind_Attack
04-10-2006 07:27 AM
chrisgottigsr
09-25-2005 09:00 PM
94lsturboteg
05-12-2005 11:19 AM
Quick Reply: turbo-set up what do you think?
