Turbo Question
Old Jan 2, 2003 | 08:49 PM
Knight2000's Avatar
Default Turbo Question
Hi guys, i got a Civic 93 EX D16Z6, i want to put a turbo on it but if someone can give me a advice i really apreciate it. I want to rebuild the whole engine so i would like to know what kind of pistons, rings, bearings etc etc etc i need to put to run more than 8psi of boost. Please i need advices. Thank you so much bye.
"ROAD's?!! Where We're Going We Dont Need Roads"
Old Jan 2, 2003 | 08:51 PM
lazy bum shaughn's Avatar
Default Re: Turbo Question (Knight2000)
You could run your stock internals with a turbo as long as your keep your boost to a minimum(I'd say about 6 or so PSI, you could run a little more but I'd do 6 to be safe). But if you want to build your block, Eagle rods and JE pistons seem to be a good setup.
Old Jan 2, 2003 | 09:33 PM
Knight2000's Avatar
What about the fuel management system, i need one? and what else i need to run a turbo with a build engine or stock
Old Jan 2, 2003 | 09:45 PM
BudaKai's Avatar
Homemadeturbo.com
If you still need help I will just learn as much as possible on your own. If you can't figure it out yourself how do you expect to have it run safely?
Old Jan 2, 2003 | 10:28 PM
A 12:1 FMU would be good, maybe a fuel pump too. Injectors and a Hondata if you're going to boost high.
Khoa_DC2
Apr 10, 2012 10:29 AM
Khoa_DC2
Apr 5, 2012 11:46 PM
JayIntegra
Sep 13, 2007 09:02 PM
Got_EF8
13
Feb 17, 2006 08:02 AM
blueb18c
Jan 26, 2006 05:56 PM
