turbo question
i've used the search button and haven't exactly found a clear forum on what i was looking for. I was just seeing a list of parts i'd probably need in order to get this turbo set up:
Turbo ( our course
Clutch
Intercooler
Fuel Pump
Injectors
B.O.V
Wastegate
downpipe??? i'm not sure what they are could someone explain?
what am i forgeting??
new ECU
Turbo ( our course
)Clutch
Intercooler
Fuel Pump
Injectors
B.O.V
Wastegate
new ECU
turbo
manifold
injectors
fuel pump
b.o.v
wastegate
downpipe is what take your wasted exaust from the turbo down and out to the exhaust system
ecu/engine manegment
feed and return lines
dump tube
map sensor if running more than (like 11 psi i think )
and a few more little things just search
manifold
injectors
fuel pump
b.o.v
wastegate
dump tube
youngwon22
Nov 8, 2003 02:11 PM
