Turbo Question!
Old Jun 10, 2005 | 07:12 AM
JDMKid71's Avatar
Default Turbo Question!
OK this must be the biggest noob question that i have ever asked, but i jsut cant find otu what A/R stands for and its bugging the hell out of me... like a T3/T4 with a 50 A/R commpresor and .63 A/R turbine... I sonud like an idiot but i just cant figuar it out.. haha. Thanks!
Old Jun 10, 2005 | 07:56 AM
BlueShadow's Avatar
Default Re: Turbo Question! (JDMKid71)
area/radius ratio
It's how you tell the sizes of turbos apart. You take the area of the fan and divide it by the radius of the fan (or was it the other way around?) and it gives you the ratio size of that fan.
Old Jun 10, 2005 | 07:59 AM
JDMKid71's Avatar
Default Re: Turbo Question! (BlueShadow)
Cool thanks!
Old Jun 10, 2005 | 09:20 AM
tech1145's Avatar
That is not exactly right. If you were to "unroll" your turbo compressor housing, you would end up with a cone. If you take a cross section by slicing the tip of this cone at any point, you have the A in A/R. Now roll the cone back up. The distance from the center of the area you found before, to the center of the compressor wheel is the R. Generally speaking higher A/R's will make a higher peak power number higher in the RPM range and a lower A/R will help out things in the low end. Also, the point you take the area from doesn't matter because the distance will change proportionally and the A/R will be the same for that turbo.
Old Jun 10, 2005 | 10:09 AM
BlueShadow's Avatar
Default Re: Turbo Question! (tech1145)
I didn't feel like taking the time to look it up earlier, but I just wanted to check to make sure. I looked in my copy of Maximum Boost in pg 32. You were right, the A is actually the area of the opening/funnel/whatever, and the R is the distance from the center of the turbo to the center of the circle in A.
Old Jun 10, 2005 | 10:17 AM
Mik3's Avatar
https://honda-tech.com/zerothread?id=1023414
Old Jun 10, 2005 | 10:32 AM
Si Shane's Avatar
Default Re: Turbo Question! (Mik3)
We need avatar police.
hondapimpin420
Jan 4, 2008 12:35 PM
Project99EK
Nov 5, 2004 10:48 PM
civic_hatchback
May 20, 2004 12:06 PM
igotyofire
May 13, 2003 11:12 AM
