Turbo Project: Greddy SOHC Kit adapting to a DOHC motor.
I recently picked up a Greddy SOHC Turbo kit w/ IC for real cheap. I bought the kit in mind that I do not want to build the block and just want a fun daily driver setup. So I need to adapt that kit on my B16 motor. Which manifold should I get? Where can I get it?What other parts would I need to modify to make it work? Has anyone else done this setup. Will the Any help is greatly appreciated.
My current setup:
B16a, Hondata Stage2, CTR Cams, ITR mani, JG Cam Gears, B&M FPR & guage, ES Oval exhaust.
TIA
My current setup:
TIA
Re: Turbo Project: Greddy SOHC Kit adapting to a DOHC motor. (HybridEF2)
well, there a HKS manifold for b16 to use t25 turbo you can use or get the manifold redrilled and port match and that should work. If not, try a search there plenty of info on this topic
[Modified by khang77642, 5:47 PM 9/11/2002]
Re: Turbo Project: Greddy SOHC Kit adapting to a DOHC motor. (khang77642)
r1lorenzini
02-20-2004 06:33 AM
integranator
01-01-2003 04:57 PM
khang77642
07-13-2002 04:09 PM
