sohc greddy kit on b16?????
Old Jul 28, 2002 | 01:10 PM
Doogie Howser's Avatar
Default sohc greddy kit on b16?????
im going to turbo my 1999 si and ive have been looking for the right turbo set up that i want, its a daily driver and i want the car to last for a while so im only going to run 6-9 psi. I want a turbo that spools up fast so ive been thinking of buying a sohc greddy kit for two reason, it spools fast with a small turbo and its only 1500, what do you guys think of this setup on a b16a2, will it be reliable,would there be problems? also has anyone done it and wat kind of times and hp numbers do they have.... thanks for the help (also i know i would have to get a new turbo mainfold)
Old Jul 28, 2002 | 01:17 PM
SlowB16's Avatar
Default Re: sohc greddy kit on b16????? (mlambrecht)
manifold is different
oops you already know that, seems like it would work though
[Modified by SlowB16, 10:17 PM 7/28/2002]
Old Jul 28, 2002 | 05:32 PM
X2BOARD's Avatar
Default Re: sohc greddy kit on b16????? (SlowB16)
It'll work, I did it a bit back onto my LS dohc motor...I no longer run that setup, but it did work well enough (with a T3) to smoke more than a handfull of quick cars.
The piping will require some 'rigging' for the I/C and you should be able to use the DP supplied, but will need to take an exhaust mani gasket and have a new flange welded onto the Mani... the manifold will not be the most efficient, but will work well. It will bottleneck slightly at the exit of the port.
You should think about selling the sohc mani and using what you get to buy a dohc mani, will give you a smoother and faster spool.
X2
Old Jul 28, 2002 | 05:55 PM
boostinb18's Avatar
Default Re: sohc greddy kit on b16????? (X2BOARD)
i have that turbo kit on my LS crx right now.......works fine and it spools very fast....its nice.....and i believe you cna put a 16g turbo on the manifold......
and all you do to the manifold is to widen the bolt holes and take out your outer most exhaust manifold studs.....its kinda ghetto but it works and its CHEAP!! good luck.
Old Jul 28, 2002 | 06:37 PM
tararan's Avatar
Default Re: sohc greddy kit on b16????? (boostinb18)
just do a clean job on the manifold and everything should look clean and proper.
Old Jul 28, 2002 | 06:39 PM
Default Re: sohc greddy kit on b16????? (tararan)
anyone have any numbers and times, also does anyone know how low of boost you can run with the sohc greddy kit?
Old Jul 29, 2002 | 01:42 PM
X2BOARD's Avatar
*sniff *sniff...... is that exhaust I smell ?
Old Jul 29, 2002 | 02:32 PM
Charlie Moua's Avatar
some one on honda-tech has this on their 99si and just used a HKS Bseries manifold, they said verything bolted up fine. Look back about 20-40 pages you'll see it garentee... there's even a pix.
Old Jul 29, 2002 | 04:25 PM
Default Re: sohc greddy kit on b16????? (Charlie)
do you know what the title of the thread was?
Old Jul 29, 2002 | 05:33 PM
boostinb18's Avatar
actually X2BOARD it doesnt leak at all! runs just fine! so
Old Jul 30, 2002 | 01:51 PM
X2BOARD's Avatar
hmmm.... I've seen that rig before (not yours).... You prolly haven't had it for over a year right ? All I have to say is....
Wait....
I'll save your for later... but hey...boostinb18.... if you're winning.... who cares what rig you have under the hood ?
BTW, boostinb18's rig DOES work despite that rig's penchant for pre turbo leaks... I've witness it before.
X2
Old Jul 30, 2002 | 10:17 PM
miyo's Avatar
How much boost can you run on this turbo for a GSR app?
Old Jul 30, 2002 | 11:35 PM
Charles B.'s Avatar
Default Re: sohc greddy kit on b16????? (miyo)
Old Jul 31, 2002 | 04:21 AM
search under creator Josh Carr.
I just posted on it,,,, it should be on the first 2pages
nihad
May 7, 2007 07:03 PM
Obie
Oct 31, 2003 12:57 PM
d15b7racer
Oct 8, 2003 06:48 AM
B-Series Sol
Jul 25, 2002 05:08 PM
