turbo problems please help
i have a d16y7 with a td04h turbo set up on it fmu ,injectors,plugs,retarded timingand i have two problems one my oil smells like gas and two when i hit 6 pounds of boost the car stutters and drops boost to 5 then it pulls again i have the missing link for the map sensor so i know its not that i would appreciate any help you can give
Re: turbo problems please help (98redDXneedsAheart)
has the car ever run right with boost?
you need the right FMU or some engine management.
the forced induction forum would be better
platinum.
platinum.
and you put the same fuel mangement on the 2nd motor.
learn from your mistakes and get rid of the FMU.
list a little more detail about your setup
what size turbo?
how much boost?
what size injectors?
what kind and size FMU?
platinum.
what size turbo?
how much boost?
platinum.
Re: turbo problems please help (platinum00)
the fuel management wasnt the problem on the first motor fuel leak causedthe motor to run lean and then DETONATION
Re: turbo problems please help (98redDXturbo)
well first off, you have bigger injectors with no fuel management. this is causing you to run ridiculously rich, washing out your cylinders, thus the gasoline in your oil. second off, the fmu coupled with the injectors is probably flooding out your engine, causing the stuttering.
