Turbo seal leaking
Old May 1, 2011 | 08:07 PM
93 Eg Couper's Avatar
Default Turbo seal leaking
I have a Turbonetics T3Super60 turbo which is leaking.
Journal bearing, its rebuildable..
The seal is leaking a little, noticing it in my exhaust pipe.
Can I still drive the car for a couple more weeks and be safe? Of course possibly having to add a touch of oil to compensate for the loss of oil..
I will be rebuilding the turbo and selling it since I have a GT3076R ready to go.
I was planning on driving the car daily still for another 2-3weeks with the turbo oil seal leak...Is this going to be safe?
ALSO, will this leak into my intake? I can check the outlet of the turbo for oil residue...If so I won't drive it.
Old May 1, 2011 | 08:20 PM
TheShodan's Avatar
Moderator
Default Re: Turbo seal leaking
No one can answer that unfortunately.. it could be new, used, due to other issues from the previous owner, or from a bad oil return line route.
Old May 1, 2011 | 08:26 PM
Did not leak last year.
Am running no restrictor -4 line, turbo has 6,000kms on it.
Ill check oil return line.
Old May 1, 2011 | 08:27 PM
Noticing a little bit of oil on the compressor wheel as well.. inside the intake shroud area.
Old May 1, 2011 | 11:33 PM
racebum's Avatar
aren't you suppose to run a -3 on most journal bearings?
Old May 1, 2011 | 11:39 PM
wantboost's Avatar
Who is Mr Robot?
feed line is wayy too big
3-an is the largest you're *supposed* to run
Old May 2, 2011 | 03:24 AM
Turbo-LS's Avatar
Id buy a -4 .060 restrictor and run it. this will drop the oil pressure down to proper operating pressures and should help some for a couple weeks till its removed, and you definatly need to be running a GT oil restrictor on that 30r
Old May 2, 2011 | 02:21 PM
I have the GT restrictor for the GT30 when its in place..
There is no oil coming from the turbo outlet so it is simply draining a bit out the seal, I guess -4 is too big.
Thanks guys.
I will continue to drive it until the GT30 is swapped in.
hold your breath
Feb 14, 2007 10:01 AM
Mr. LS VTEC
Sep 17, 2006 10:51 AM
Mr. LS VTEC
Sep 16, 2006 05:39 PM
1FastLS
Mar 31, 2006 04:33 PM
SynTeg
Jul 28, 2004 01:27 AM
