New Build, Wont turn over HELP!
Ok i have a gsr that i recently built with a new .20 pistons and rods,balanced crank , new oil pump , new water pump. I primed the engine a couple of times and the put the spark plugs and fuel pump connector back on. It turned over about 3 times, didnt fire, then it just stopped. The fuel pump wont come on and the starter wont activate. So i got a brand new battery, tested the starter, got a new main relay and still nothing happens. I was reading in my manuel about if the the motor goes under 4.3 psi of oil pressure the fuel pump wont turn on? But i have no idea what is goin on, any help would be greatly appreciated....Thanks
Re: New Build, Wont turn over HELP! (mademan2723)
oil pressure sender is most definately not wired to the fuel pump.
It won't turn over at all? Not even a click?
Re: New Build, Wont turn over HELP! (dustin)
Thats all been done, its just weird it was doing it then just stopped..Thats why i thought it was the main relay, but it wasnt
already did that with a screwdriver, and a wire....nothing happened though , advanced auto did it when i took it out and it Worked! WTF
yeh , im gonna sand them all down.......but that wouldnt have to deal with the fuel pump not turning on would it ?
this might be a dumb question but there are 3 wires connected to the starter right? Power, ground and a signal wire?
Re: (kennyc)
i used a jumper wire in the main relay harness to turn the fuel pump on...it turns on then, but the main relay is good so i dont know whats goin on
Re: (mademan2723)
i dont see how the main relay can be good and when i jump the fuel pump it works , it still seems like the relay is not doing its job, but when i hooked it up to my batt it worked fine
Re: (mademan2723)
no ecu codes? I had a bad ecu which didn't kick the fuel pump on. i had a solid code on my ecu, no flashes. put in a ecu from another car and it fired right up. didn't have any problems with starter though, maybe there's a starter fuse or relay or connection bad
Re: (ramennoodles)
oh yeah I saw a thread about people blowing some voltage regulater in the ECU, which prevents the fuel pump to turn on... you should check that out at least, open the ecu...
now that I think of it, not sure if it was a capacitor that burns out instead, I'll try to find the thread.
