-turbo problem-
Old Oct 22, 2003 | 06:16 PM
0 0 0's Avatar
Default -turbo problem-
i have a t25 turbo that had minor shaft play(suposidly just had new seals put it) that i just finished installing. i cranked it up and oil leaked out of the return line. does the return line have to be a certian diameter? im thinking mine is too small... some oil came out of the downpipe that was hangingtoward the ground. im thinking either the seals in the turbo are bad or the oil return line s too small and the downpipe is right there for it to drain into.
what is the problem?
Old Oct 22, 2003 | 09:22 PM
Johnyquest's Avatar
Default Re: -turbo problem- (vxHATCHATTACK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxHATCHATTACK &raquo;</TD></TR><TR><TD CLASS="quote">i have a t25 turbo ... and oil leaked out of the return line</TD></TR></TABLE>
LOLOLOL that's rediculous.
Old Oct 23, 2003 | 06:23 AM
0 0 0's Avatar
Default Re: -turbo problem- (Johnyquest)
how is that informative......? i dont care for rediculous comments. im trying to solve a problem i dont wanna hear your ****
Old Oct 23, 2003 | 08:03 AM
hondahvn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxHATCHATTACK &raquo;</TD></TR><TR><TD CLASS="quote">how is that informative......? i dont care for rediculous comments. im trying to solve a problem i dont wanna hear your ****</TD></TR></TABLE>
good call no room for dicks here this guy just needs help. no one is born an expert...
where is the oil leaking from who put seals in it how much play is classified by a little...
Old Oct 23, 2003 | 08:12 AM
PeakBoost's Avatar
B*A*N*N*E*D
what size feed and drain line are you running?
Old Oct 23, 2003 | 05:50 PM
0 0 0's Avatar
Default Re: -turbo problem- (CHEAPTURBOdotCOM)
the feed is 3/8" outside diameter and the return is the same but the inside is around an 1/8"
Johnyquest's Avatar
My apoligies. But when someone said they just installed their turbo and oil came out the return line, I get all giddy like a little kid. I don't really see the question here. If it came out the exahust side of your turbo, your oil is too thin or your seals are shot. Try thicker oil (mobil 1 10w50). It solved my minor smoking problems!
Old Oct 23, 2003 | 05:53 PM
0 0 0's Avatar
Default Re: -turbo problem- (hondahvn)
the kid i bought it from put the seals in, the oil is leaking out of the downpipe and from the return line, 1/4 play up and down hardly any side to side
Old Oct 23, 2003 | 05:55 PM
0 0 0's Avatar
ill try thicker oil i was using 5w 30 i thought the thinner would work better
Old Oct 23, 2003 | 05:58 PM
BlueSi2k's Avatar
try a smaller feed and larger return. Most of us run -3an(3/16) feed and -10an(5/8) return. Even with this im getting some oil past my compressor seal on a brand new turbo. Im gonna try a restrictor in the feed line.
Old Oct 23, 2003 | 06:07 PM
0 0 0's Avatar
Default Re: -turbo problem- (BlueSi2k)
so could i be feeding too much oil ? i didnt think the oil would feed any faster cause the pump will oil pump so fast and a smaller line would just create more pressure
im gonna try a bigger return line tomorrow
Old Oct 23, 2003 | 06:14 PM
BlueSi2k's Avatar
true but its less of a volume...but definately try a bigger return first or maybe some type of restrictor on the feed.
Old Oct 26, 2003 | 08:19 AM
0 0 0's Avatar
where could i get a restrictor?
Old Oct 26, 2003 | 08:21 AM
BlueSi2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxHATCHATTACK &raquo;</TD></TR><TR><TD CLASS="quote">where could i get a restrictor?</TD></TR></TABLE>
try searching...someone recently posted in the forum about selling them.
bboyfreeze
Apr 2, 2007 08:38 PM
civicek00
May 31, 2005 09:38 AM
dturbo
Apr 5, 2005 03:44 PM
mike1114
Mar 28, 2005 08:01 AM
