Turbo Problem
Old Dec 14, 2004 | 04:49 AM
  #26
dawrenn's Avatar
Default Re: (PrettyLude)
I thought if the seals were going there would be shaft play. Someone said it NORMAL for some oil to be in the I/C.
Old Dec 14, 2004 | 01:04 PM
  #27
StrokedPSI's Avatar
Default Re: (dawrenn)
no, if the seals are no good you'll leak oil into the turbine or compressor housing (if you see it in your intake tube you've got bigger problems). The shaft play is when the bearing is worn and there isn't as tight of a clearance to the shaft anymore. Clean out the oil in the tubes and Try the 20w50! Plus the 20w50 is better for engine wear/ turbo wear anyway, and being in VA you don't really need to worry too much about the temperature coming into play with oil selection.
Old Dec 15, 2004 | 08:13 AM
  #28
Benjithx's Avatar
Default Re: (StrokedPSI)
oil was getting in to my intake through the valve cover breather hose. I took it off and put in a small filter.
Old Dec 15, 2004 | 11:40 AM
  #29
StrokedPSI's Avatar
Default Re: (Benjithx)
i did the same thing but i did it before i started the engine the 1st time though.
Old Dec 21, 2004 | 06:55 AM
  #30
dawrenn's Avatar
My friend is still worried about his car. He wants to know if the turbo is messed up AKA bad turbo seals will it mess up the engine?
Old Dec 21, 2004 | 07:26 AM
  #31
LS_REX's Avatar
YES! Oil is sooner or later going to get into your combustion chamber. Oil in the combustion chamber will cause detonation under boost and BAM!! No more ring lands......
Rob
ProjectEG8
Jun 19, 2007 09:59 AM
Canuk_SiR
Feb 26, 2005 02:00 PM
dawrenn
45
Dec 22, 2004 08:34 PM
shadowdawn
Aug 31, 2002 04:14 PM
