GE VTEC conversion oil kit
Old Apr 24, 2003 | 08:47 PM
M.A.R.C.'s Avatar
Default GE VTEC conversion oil kit
OK I got the kit.
how do i take the stock oil filter nipple out of the block to install the new one? I was checking it out on my spare block and I don't see how to get it out (no socket can fit, etc) anyone know how to get it out?
Old Apr 24, 2003 | 10:48 PM
SiR Kid's Avatar
New User
Default Re: GE VTEC conversion oil kit (CivicRyda2k)
Big crescent wrench on the hex head that's built into the filter bung thing
Sorry, can't explain it better, but look at the center screw thing that came with the conversion kit, and you'll see the big hex head.
Old Apr 24, 2003 | 11:00 PM
V-SPEC 1's Avatar
Default Re: GE VTEC conversion oil kit (SiR Kid)
yeah! just use a good vise grip and it'll come loose. Mine was a little tight but I got it out.
Vic
Old Apr 24, 2003 | 11:20 PM
LsTurbo91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">Big crescent wrench on the hex head that's built into the filter bung thing
Sorry, can't explain it better, but look at the center screw thing that came with the conversion kit, and you'll see the big hex head.</TD></TR></TABLE>
Hmm, so you have to remove the filter thread on the block? What fittings are needed on the kit? 1/4npt -3an?
Old Apr 24, 2003 | 11:48 PM
SiR Kid's Avatar
New User
Default Re: GE VTEC conversion oil kit (LsTurbo91)
Depends on what you're using the kit for. If you are using it to run a VTEC head on a NON VTEC block, GE already included the fittings you'll need.
If you're running a turbo, You'll need a -10AN(90% certain) to whatever size your feed line is fitting (-3 or -4 usually).
Just take the fitting that came screwed into the GR adapter out, take it to a fitting store, and buy one that has the male ends that fit your feed line, and the other male end the same as what came with the kit, which I think is -10an.
Old May 7, 2003 | 09:53 AM
M.A.R.C.'s Avatar
i checked it out and i understand it now. well kinda. I was doing the oil feed line on a friend's turbo gsr and I saw the hex head. However... on the spare d16z6 block i have in my garage there's no hex head and the filter bung thingy looks like one part of the block. I'm not sure how the d16y8 one in my car looks though... can't remember.
here's a pic of the d16 block
Old May 7, 2003 | 11:39 PM
youngkow's Avatar
If you got the old model from GE, use a vise grip and it'll come right out.
Old May 8, 2003 | 12:00 AM
SiR Kid's Avatar
New User
Default Re: GE VTEC conversion oil kit (youngkow)
BTW, I'm currently installing my GE kit for my turbo car that HAD an oil cooler. It's MUCH easier to pull the intake manifold and work from the top if the engine is still in the car, FYI. I just hate all the damn water lines and **** I have to undo to pull the manifold! Anyway, I used one of the oil cooler's lines to bridge between the two ports on the waterjacket instead of jsut buying two caps for it. Should work fine. I have to get the AN fittings I need for the oil feel line before installing the part now. Wish me luck.
My thumbs are all cut up and crap from sharp edges and hose clamps... Life sucks for meeeeeeee.
BWRSUPPORT
Performance
37
Oct 14, 2013 01:56 PM
1997IntegraGS
Oct 25, 2006 08:56 AM
1slowEK
32
Jun 8, 2005 10:16 AM
skribblah
27
Aug 22, 2003 11:31 PM
