broken turbo?
Old May 21, 2004 | 01:22 AM
mattcalica's Avatar
Default broken turbo?
okay, heres the deal. My turbo is making this really weird, loud, howling sound, when its supposed to spool. It is a brand new turbo. I can spin the turbo with my finger, but yet it makes this sound. Is it something to do with my turbo? and no, its not a charge pipe leak, vacuum leak, or exhaust leak. I am also making absolutely NO BOOST. my wastegate is also not opening, so nobody say its the wastegate. All i want to know is whether the turbo can be bad, even though it spins.
Old May 21, 2004 | 02:13 AM
vaporboy12's Avatar
check to make sure all your charge pipes are together and tight
Old May 21, 2004 | 02:16 AM
mattcalica's Avatar
okay, like i said...no leaks, ANYWHERE...i PRESSURE CHECKED THE WHOLE SYSTEM. please, next person, just answer the question. can my turbo be bad even though the wheels spin?
Old May 21, 2004 | 02:33 AM
vaporboy12's Avatar
i telling you there is a leak somewhere or your wastegate vacum isnt hooked up
Old May 21, 2004 | 02:11 PM
mattcalica's Avatar
dude, can you read? honestly, come on....I PRESSURE CHECKED MY WHOLE SYSTEM WITH AN AIR COMPRESSOR. THERE ARE NO LEAKS!!!!!!!!! i am just asking whether or not a bad turbo can still spin...
Old May 21, 2004 | 05:16 PM
h22 civic's Avatar
Default Re: (mattcalica)
yes it can oil in the compressor are first tell tales of a shot turbo
Old May 21, 2004 | 05:22 PM
sporkcrx's Avatar
Default Re: (h22 civic)
LOL, hate to beat a dead horse but it sounds like a leak to me.
Old May 22, 2004 | 12:03 AM
mattcalica's Avatar
turbo is not leaking oil...
Old May 22, 2004 | 12:14 AM
b_ron007's Avatar
blow-off valve stuck open?
Old May 22, 2004 | 12:17 AM
b_ron007's Avatar
run the car at idle, rev it from in the engine bay.....do you feel the blowoff valve blowing?
Old May 22, 2004 | 12:19 AM
b_ron007's Avatar
take off the air filter and look at the compressor while at idle. spin the wheel.....does it spin freely? is it spinning at idle?
Old May 26, 2004 | 03:04 PM
mattcalica's Avatar
okay, well i sent the turbo back, and they refunded my money. wheres the cheapest place to get a new t3/t4 turbo?
Old May 26, 2004 | 11:35 PM
mattcalica's Avatar
bump
Old May 26, 2004 | 11:48 PM
1316130057's Avatar
lol, it's definitely not a leak. Turbs that howl (instead of spool, you hear "wooooooooOOOOOOOOOOooooohh" = dead turbo, which with enough complaining, Turbonetics replaced (after 2 months). It almost sounds like someone is making the sound from a machine or something right? If so, then I GUARANTEE that the compressor wheel is damaged to ****. I've seen a T04X (same turbo as Lisa Kubo) turn to a kazoo because the owner put a low-output BOV on it and the compressor surge bent the inducer and grenaded the turbo something nasty. It still made like 1-2lbs of boost (because it was the inducer, not the exducer) but it always makes the same sound. If you aren't seeing any boost then it's more than likely the exducer which is shrouded within the compresor housing.
Take the 5 bolts off of the back and see for your self.
What's weird is that you never hear the pieces break off or flying around, and you probably won't find the chunks of turbo (which are stuck in the scroll which makes the whistling sound). Just out of curiosity, what BOV was it, what psi were you running, and what turbo?
jdmdikk
Apr 20, 2009 08:45 AM
RFd15bhatch
Jul 1, 2005 02:05 PM
99CRX-SI
Sep 29, 2004 09:27 AM
b00stedbyFastrax
May 11, 2004 02:55 PM
