difference from t3/t4 and t3/t67
Old Jun 8, 2004 | 07:22 PM
BoOsTiN Dc2's Avatar
Default difference from t3/t4 and t3/t67
i was wondering which turbo is bigger... i have a t3/t4 ar63 .57 trim and was wondering what size is the t3/t67 that full-race sells and whats the limit on these turbos... i know the one that i have is around 500hp... also just to double check will the t3/t67 bolt on to my t3/t4 manifold?
Old Jun 8, 2004 | 07:23 PM
Default Re: difference from t3/t4 and t3/t67 (tRaCeBuStAbUsTeR)
also at what rpm will it get full boost by....
Old Jun 9, 2004 | 07:37 PM
94gsr4dr's Avatar
Yes it will bolt-on to a t3 flanged manifold. It is much bigger than your turbo. This turbo has already make 600+ at the wheels. Cannot tell you when the turbo would spool without a complete rundown of your set-up.
Old Jun 9, 2004 | 11:24 PM
Default Re: difference from t3/t4 and t3/t67 (94gsr4dr)
a ls vtec with a 81.5mm bore... what kind of specs range is the t3/t67 at?? is the compressor side bigger and the exhaust side the same size or so?
civichbsi1590
Feb 23, 2011 02:12 PM
sikid111
Sep 20, 2010 10:16 AM
Sloshy
Dec 17, 2007 07:34 PM
EJ8 GSR-T
Feb 13, 2006 08:04 PM
