Radiator coolant
Old Jul 24, 2008 | 10:57 AM
scspeed's Avatar
Default Radiator coolant
Looking for the best one to put in my new aluminum radiator. I herd there was a coolant that lowers engine heat by like 10% better than the others? which brand is that? and what exactly will i need to buy along with this to mix. 50/50? Iv never changed my coolant before. lmk
Thanks.
Old Jul 24, 2008 | 11:50 AM
TehGhett0P1mp's Avatar
Default Re: Radiator coolant (scspeed)
Dont understand why this is in FI, but cant beat OEM
Old Jul 24, 2008 | 02:53 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Radiator coolant (TehGhett0P1mp)
look at the bottle of what ever you use. there is a % on the back that will tell you the best level of protection.
water wetter works pretty well.
ifthis is a track car, please use only water, if anything bad happens, it is faster and easier to clean up water, than it is glycol.
if you do just use water, get a cooling system conditioner for aluminum engines. it keeps from coroding the aluminum parts.
Old Jul 25, 2008 | 03:08 AM
DreTec's Avatar
Get direct from Honda (find out exact grade in handbook) but their stuff is the best for their engines! I've been warned harsher coolant can easily corrode bits over time, and only ever use deionised water... too much crap in tap water!
Old Jul 26, 2008 | 11:17 AM
soclean1k_JDM's Avatar
check out this stuff called water wet-er i think this company redline makes it. i think you can find it at any autozone or pepboys.
Old Jul 27, 2008 | 08:55 AM
Default Re: Radiator coolant (soclean1k_JDM)
redlineoil.com (this was on the bottle) water wetter [cost $10]
it suppose to keep it 20 degrees cooler
Old Jul 27, 2008 | 04:37 PM
rorik's Avatar
yeah, whatever you use, use distilled water with it instead of tap water, no minerals/ions so it doesn't conduct electricity and corrode anything. I don't recommend using only water, the antifreeze does other things like lubricate the seal on the water pump too..
scspeed
Jul 30, 2008 04:01 AM
SamC
Dec 8, 2007 07:55 AM
Ef Whore
Jul 27, 2003 11:36 AM
rolow
Jun 28, 2002 02:39 PM
94vteclude
May 18, 2001 01:58 PM
