Turbo / Manifold question
Old Aug 28, 2011 | 06:01 PM
wespirl's Avatar
Default Turbo / Manifold question
Has anyone tried running a inlinepro manifold with a billet 6262??
Would like to know if there are any turbo/block clearance issues... need to keep A/C
Thanks for the help!!!
Old Aug 28, 2011 | 06:17 PM
TheShodan's Avatar
Moderator
Default Re: Turbo / Manifold question
Check INLINEPRO Setups with T04S covers (GT35R, T3/T67,60-1), since they have same diameter as those . Anything that has the 5 bolt turbine housing will somewhat fit, but not without some work on grinding the block.
Old Aug 28, 2011 | 07:00 PM
Turbo-LS's Avatar
You can get an E cover 6262, it wont make to much less power than the s cover unit.
Old Aug 28, 2011 | 07:59 PM
TheShodan's Avatar
Moderator
Correct, and the same still applies. Check out fitments for standard T3/T4s in E Covers, and you'll have your answer.
Old Aug 29, 2011 | 04:56 AM
Turbo-LS's Avatar
very slight if any grinding on the block will need to be performed witht he inline pro and definatly need that 5 bolt turbine housing to make it happen Like Shodan already mentioned
Old Aug 29, 2011 | 10:22 AM
wespirl's Avatar
Ok... thanks for the help guys... appreciate it.
I was running the inlinpro manifold with a SC61 on my last setup and didn't have any clearance issues... so figured the 6262 with the E cover would only be a little bit bigger
Old Aug 29, 2011 | 01:15 PM
Turbo-LS's Avatar
If you were running an sc61 with an S cover then it will fit fine. the 6262 is the same outter dimensions as the sc61 just better wheel design internally.
Old Aug 29, 2011 | 04:11 PM
TheShodan's Avatar
Moderator
You got it backwards a little there, chief... S cover is larger in diameter than E. the order goes L,<B<,E<,S<,H
Old Aug 29, 2011 | 11:11 PM
Redline130's Avatar
I'm using a 6765 with an InlinePro manifold, no block clearance issues at all. Not sure about a/c though.
BoostedEgHatchFl
Nov 10, 2009 03:12 AM
7mile
Aug 4, 2009 01:19 PM
Manny1987
Sep 13, 2008 09:31 PM
crazy_eddy
Jun 11, 2006 05:26 PM
downeyballz
Jan 30, 2005 10:10 PM
