Blox Manifold SC61/GT35R
will the blox manifold (cast iron ), work with the prec. sc61's/gt35rs? with a t3 flange.. just wondering, going to upgrade the turbo and needed info befor doing so. right now i have a t3/t4 on the blox mani.
i'm actually talkin about clearance and fitting
if this is possible could some of you guys post pics of this. thanks
Re: Blox Manifold SC61/GT35R
i have the revhard cast mani with a 35r and it work fine...im pretty sure the mani is the same as the blox, i made 454 to the ground on 18 pounds
Moderator
If either turbo is in a T04E cover (7" diameter) similar to most any T3/T04E, then you will more than likely fit the engine bay with a small amount of block notching (assuming it is facing passenger side, of course). If not, you may have to do a bit of grinding.. It depends upon how your current turbo is fitted and what you have.
35R will not fit
and you need to have a 5 bolt turbine outlet pattern
a 4 bolt definately will not fit with the blox manifold
none the less at t04S compressor housing ( 4 inch inlet 2.5 outlet)
UNLESS you run it non ac style and flip it around with the intake./compressor on the driverside
you will not keep a fullcore radiator with it setup like this.
Moderator
An "S" cover would fit if it were facing the driver's side like the pic above. The OP seems to imply he has A/C and needs it to face the passenger side w/ his blox manifold. He could always switch to the opposite direction and make a new Downpipe to fit.
