Turbo LS/Vtec
Old May 6, 2006 | 02:22 PM
specc's Avatar
Default Turbo LS/Vtec
B18b Bottom .. stock bottom end
B16a Head .. GSR cams
... my question is ... is this safe to boost at low PSI.. if so what PSI would be recommended (when tuned properly of course) .. and what would you recommend to strengthen this build to make it more stable to boost on for minimal amount of money ..
(not looking for the obvious... sleeve it .. pistons / rods / etc because i am building up another block properly .. just cant afford it all at once at the moment)
Old May 6, 2006 | 02:56 PM
Zakar's Avatar
you could always just get pistons/rods and forget the sleeves.. it cuts the build cost practicly in half
use the compression estimator to see what CR you would get using the b16a head on that block.. then you can get an idea..
Old May 6, 2006 | 03:29 PM
Dc4turbo408's Avatar
Default Re: Turbo LS/Vtec (specc)
With your setup is pretty safe too boost 10 or a little more if u can find a good tunner.. If im you, i would look into hondata.. Please dont tell me u gonna run on a fmu and a missing link..
Old May 6, 2006 | 03:53 PM
specc's Avatar
Default Re: Turbo LS/Vtec (LsvtecBoi408)
well i run uberdata atm ... that should be sufficient for low boost until i get the other block / head done right ?
Old May 6, 2006 | 04:10 PM
SavEM1's Avatar
lsvtec blocks are just as fine as any other b-series blocks, its all in the tune and the build.
Piston and Rods and you are good to go.
Old May 6, 2006 | 05:43 PM
beerbongskickass's Avatar
Default Re: (Hcivic02)
B-series motors can handle 300whp give or take. What "PSI" you run doesn't matter. Just make sure your car is tuned well.
Dugdude
Aug 25, 2013 11:43 PM
civproject14
Jan 31, 2005 05:19 PM
aut0tek
Apr 2, 2003 02:50 AM
HarryB
May 23, 2002 12:15 PM
