Turbo install progress... and ?'s
Old Jun 2, 2003 | 12:57 PM
technine's Avatar
Default Turbo install progress... and ?'s
Well, I have been slowly installing my junkyard turbo on my daily driven civic (I love how that is possible). So far I have installed the fuel management (filetofit circuit, 450cc DSM injectors and an cartec FPR/FMU adjustable) and this saturday afternoon I installed the oil pan w/ drain fitting that I plugged off.
So I guess all I have left it put on the manifold and IC, charge pipes and oil/coolant lines.
My question is on the Oil lines. If I take off the oil sender, will a lot of oil come pooring out resulting in needing to drain the oil first or can I get away with changing out the sender to put in my oil fittings/lines?
Old Jun 2, 2003 | 02:24 PM
technine's Avatar
Default Re: Turbo install progress... and ?'s (technine)
Also, does anyone know where I can get vacuum caps? My oil fitting is leaking from the what I have to plug off the inlet with. I need a cap, but I can never find one.
Old Jun 2, 2003 | 05:20 PM
technine's Avatar
Old Jun 2, 2003 | 07:03 PM
scttydb411's Avatar
just drain the oil, remove the sensor and run lines. it'd be good to have fresh oil anyway.
Old Jun 2, 2003 | 07:30 PM
specie's Avatar
I remembered with I change my oil pressure switch (?), oil didn't gushed out. The oil should be near the top of the oil pan, I don't think it goes higher than that.
Have fun with the project.
endlessdv
Mar 25, 2004 04:55 PM
Screamer
May 14, 2003 11:35 AM
dave'sh22a4
Jan 21, 2003 07:41 PM
TurboDragger
Aug 29, 2002 05:46 AM
rice4life
May 9, 2002 06:57 AM
