Oil Pressures & Oil Temperature
Where is the right place to install your Oil pressure and Oil Temperature sensors for gauges??? Just wondering where are the correct locations to give you correct readings.
Thanks,
Rafal
Thanks,
Rafal
Re: Oil Pressures & Oil Temperature (Screamer)
Oil temp: in the pan where the oil pools
Oil pressure: Just tee it into your oil feed line, check out http://www.theoldone.com for the directions, I'm too lazy to find them myself.
edit: learn to be a litttllee more patient, I see you bumped your post only after an hour of waiting.
