Oil Cooler install?
Old Aug 25, 2002 | 02:47 PM
TurboDragger's Avatar
Default Oil Cooler install?
Hiya... I have a oil cooler for my turbo crx that I want to install, but am a little worried about the stock oil pump... I was planning on cutting the oil feed line for the turbo and putting the oil cooler right before the turbo. Will this put a bad strain on the oil pump.. also is this the ideal location?
Old Aug 25, 2002 | 10:09 PM
Smashback's Avatar
Default Re: Oil Cooler install? (TurboDragger)
I just asked this question a week or two ago. The general opinion is that it's not a good way to do it.
Get a sandwich adapter and run your feed/return for the COOLER from there and keep your oil feed/return for your turbo the way it is.
Old Aug 26, 2002 | 05:25 AM
Default Re: Oil Cooler install? (mplex2000)
So youre saying that I should use entirely new lines for the oil cooler feed and return?
Old Aug 28, 2002 | 05:43 PM
eg9
Guest
Posts: n/a
yes
Old Aug 28, 2002 | 09:22 PM
MyWhiteCivic's Avatar
From the oil sending unit? Sorry that is most likely a dumb *** question but I would like to know where I should tap into for the cooler lines.
Old Aug 29, 2002 | 05:25 AM
Bnjmn's Avatar
Why is putting the oil cooler before the turbo a bad idea? On a B18C1 (I know the poster is asking a D series), you already have an water to oil cooler at the filter, so what is the harm in putting a cooler before the turbo as well?
Ben
Old Aug 29, 2002 | 05:46 AM
Default Re: Oil Cooler install? (Bnjmn)
I did a little more research and it looks like what I need to do is buy the sandwich adapter that goes between the oil filter and the block and run the lines off that.
tremor86
Jan 13, 2005 10:26 AM
15psi of fun
Feb 4, 2003 10:17 PM
Smashback
Aug 15, 2002 08:44 AM
rice4life
May 9, 2002 06:57 AM
