Turbo install HELP!
Old Nov 10, 2003 | 08:30 PM
Boostin95Teg's Avatar
Default Turbo install HELP!
ok during my turbo install...i've ran into every problem possible....now that those are all settled, i have a big problem...no boost....it idles at the vacum mark of 20, which i was told was normal..but when i drive the boost guage only goes to 0 then stops...no boost....even when i hold the wastegate open no boost....i hear the turbo spoolin, but i'm getting no power, not even enuf for me to hear the blow off releasing air, the blow off is operating correctly...the flap inside there closes when i give throttle, and opens when i let off.....what could be my problem... all the intercooler piping is tight...no leaks. The car is a 95 acura integra LS
ps. where do i run the vacumm line off the wastegate actuator?
Old Nov 10, 2003 | 08:32 PM
baphomet's Avatar
Default Re: Turbo install HELP! (Boostin95Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostin95Teg &raquo;</TD></TR><TR><TD CLASS="quote">.even when i hold the wastegate open no boost..?</TD></TR></TABLE>
Wouldn't you want the wastegate closed to build boost?
Old Nov 10, 2003 | 08:36 PM
luti's Avatar
Default Re: Turbo install HELP! (slashDEVslashNULL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldn't you want the wastegate closed to build boost?</TD></TR></TABLE>
Yes you do. Also, how do you know for sure the BOV is working, does it have an adjustment screw? If so tighten it down a bit and see if that helps.
The vacuum line for the wastegate can come from any vacuum sorce.
Are you running an intercooler? If so does it have a leak? Is the charge pipe from the turbo on securly? I had mine blow off once under some extreme exceleration
Old Nov 11, 2003 | 03:41 PM
Default Re: Turbo install HELP! (luti)
how do i know if my intercooler leaks? try boosting it without it on? when i hold the flap all the way to left i can hear the turbo spoolin....hold to the right i cant....should it sit to the left or right?
Old Nov 11, 2003 | 04:15 PM
luti's Avatar
I have no idea, I have an external wastegate.
Old Nov 11, 2003 | 04:25 PM
anyone?
ZoRG
May 30, 2005 03:34 PM
skierGT
Jun 21, 2004 09:32 AM
blackfrohatch
Aug 26, 2003 06:47 AM
nd8ch
Aug 26, 2003 04:47 AM
