turbo install help!!!
Old Mar 16, 2008 | 12:28 PM
efking1985's Avatar
Default turbo install help!!!
which vacum lines do i run and where do i run them to?
Old Mar 16, 2008 | 12:52 PM
efking1985's Avatar
Default Re: turbo install help!!! (efking1985)
help anyone
Old Mar 16, 2008 | 12:57 PM
97_coupe's Avatar
https://honda-tech.com/zerothread?id=118699
Old Mar 16, 2008 | 01:00 PM
efking1985's Avatar
Default Re: turbo install help!!! (97_coupe)
which vacum lines do i have to run only the wastegate?
Old Mar 16, 2008 | 01:05 PM
97_coupe's Avatar
wastegate, BOV, Boost gauge. You should really check out https://honda-tech.com/zerothread/1024174 There is tons of good info.
Old Mar 17, 2008 | 09:11 AM
efking1985's Avatar
ok so just the wastegate, BOV, Boost gauge have a vacum line. now what do i do about fuel i saw omni power has a map sensor that reads up to 43 psi will this work to add more fuel in the mean time till i get tuned?
Old Mar 17, 2008 | 09:29 AM
RubenPrelude's Avatar
Dude, you have A LOT to learn. Read!!!!!You are asking questions which are the basics of turboing a car..
Old Mar 17, 2008 | 09:35 AM
jmm96gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 &raquo;</TD></TR><TR><TD CLASS="quote">ok so just the wastegate, BOV, Boost gauge have a vacum line. now what do i do about fuel i saw omni power has a map sensor that reads up to 43 psi will this work to add more fuel in the mean time till i get tuned?</TD></TR></TABLE>
read the links the other members are posting
Old Mar 17, 2008 | 09:43 AM
efking1985's Avatar
Default Re: turbo install help!!! (jmm96gsr)
ok but is there a diagram where to put the vacum lines at?
Old Mar 17, 2008 | 10:11 AM
blwn95civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efking1985 &raquo;</TD></TR><TR><TD CLASS="quote">ok but is there a diagram where to put the vacum lines at?</TD></TR></TABLE>
If you dont know the basics of hooking up the vacume system properly then you shouldnt be trying to turbo your car.
Old Mar 20, 2008 | 06:31 AM
Singlecam4dr's Avatar
Default Re: turbo install help!!! (blwn95civic)
Owned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blwn95civic &raquo;</TD></TR><TR><TD CLASS="quote">
If you dont know the basics of hooking up the vacume system properly then you shouldnt be trying to turbo your car. </TD></TR></TABLE>
TheOdd001
Mar 17, 2010 05:07 AM
dcintegra88
Jan 18, 2010 01:42 PM
krysted9354
May 10, 2009 11:13 AM
90AcuraIntegra04
Jan 28, 2006 07:02 PM
ceemarun
Jun 4, 2002 06:33 PM
